Question about Indesit W 123 Front Load Washer
The machine just empties its water without filling up the drumb
  • Indesit Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Oct 10, 2010
Machine fills then emptys without washing
The first thing that comes to mind is that the drain hose might be too low and is siphoning the water out of the wash machine as it is filling. Try to raise the drain hose up and see if that helps any.
Let me know how it goes.
Dec 24, 2014 | GE Profile WPRE6100G Top Load Washer
Fill with water on indicator
Remove the water reservoir clean the inside and dry. Pull the filter screen and rinse. Put 2 cups of water in the container and shake well for a few minutes. Empty and Dry again. Reset as per the manual, fill to the line and with the filer removed, do a dry run without the kcup in place.
Feb 01, 2014 | Keurig B70 Coffee Maker
When the water has reached it's proper level, the hot water turns off, but the cold water keeps filling until the water overflows the basket
Try this. With the wash tub empty, start to fill with water. Without turning washer off, unplug the washer from wall.
If water filling stops (hot and cold), then you are looking at a bad timer assembly. Replacement isn't that hard, parts can be difficult to find though.
If water continues to fill, your valve body / solenoid assembly is likely full of lime-scale. Easily replaced.
Jan 04, 2010 | GE WVSR1060A Top Load Washer
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water drains out as fast as trying to fill
hello, have you checked to see if your drain valve is'nt stuck open ?
Mar 31, 2009 | Washing Machines
The washing machine fills and then empty without running a
Without more info, brand, model, age, etc. I will still try and help you. If you wish to provide more details than I can give you a better help description. With the info you have provided I can only give you the most common oprobable causes.
The machine will fill and discharge but the drum won't turn.
Most motors on washing machines today are fitted with carbon brushes. The carbon brush is the most common reason for failure of motor action. Check carbon brush for wear and replace if necessary. The drive belt may have come off the pulley. Check and if necessary replace. The bearings may have gone out in the drum - causing the belt to have come off. Check and replace bearings. Component failure in order:- 1. Belt 2.carbon brushes. 3. motor. 4. timer. 5. lid switch, selector switch, module. (depends on age and brand),
Finally, Perhaps something is caught in the trap at the bottom. There may be a plug. If not than removal is the only option. Check for lodged clothing items, or excessive lint build up. One thing I would do before removing the trap is make sure that all the water has drained from the machine - It you don't it will flood the floor. Check for lodged clothing or excessive lint build up.
Mar 06, 2009 | Washing Machines
Indesit W 123 Front Load Washer Logo
32 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
