Question about Kodak ESP9 All-in-One w/USB Cable & 4x6 Premium Paper InkJet Printer
I have a Kodak ESP 7200+0396 When I first installed it on my laptop using the WiFi, it worked fine. I've scanned pictures on a few different occasions without problems. Just now is the first time I've tried to print with it. It was saying that the printer wasn't detected. I couldn't figure out how to get it to work, and was about to just use the usb cable... The printer came up under Control Panel > Printers. After going into the printers properties and clicking on "Print test page", suddenly it was detected. I canceled the test page and proceeded to print my pictures with no other problems. In the reviews I've seen for this, other people have had a problem with the WiFi not working right... are we missing something? Do I need to "print a test page" everytime I need to use the printer?
Disconnect your wifi connection on your labtop then reconnect it fix the problem for me good luck
Posted on Mar 14, 2011
No color
Go to support on the Kodak website. Enter your model number and click on downloads. Select driver and download it. The software will guide you through the installation.
murf427
Aug 02, 2012 | Kodak ESP 5 Printer
I have a Kodak ESP5210. Its an all-in-one with the printer, copier, and scanner. I can't get my scanner to work. I put a picture on it and hit "Start" and all it did was keep saying scanning. It...
Make sure any other scanners are disconnected from your computer. I had a problem with the scanner in the Kodak ESP 7 AIO printer. Kodak advised me to disconnect my other scanner. After I disconnected my Canon scanner, I was able to use the Kodak ESP 7 scanner.
MWR
Feb 28, 2011 | Kodak ESP 5 Printer
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just installed a new Kodak ESP 5210 printer. It will not print out documents, it will copy and scan though.
OK, did you install the Easyshare software first before installing the printer? I've experienced technical problems with my Kodak camera when I do not have the Easyshare software installed.
Also, how did you install the Kodak ESP 5210 printer? Did you use the driver from the Kodak.com website, or the CD that came with it?
Good luck on getting the Kodak ESP 5210 printer to work on your computer system.
Dec 18, 2010 | Office Equipment & Supplies
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 5 won't scan
call kodak @ 1800 421 6699. This step involves advanced troubleshooting and is related with the scanner drivers of the Printers. Kodak telephone support will take care of the issue.
Sep 20, 2009 | Kodak ESP 5 Printer
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Can't get computer and printer to communicate
Make sure the wireless LAN of your computer is set to AdHoc mode if the Printer is set to that function.
Mar 11, 2009 | Office Equipment & Supplies
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
Kodak ESP9 All-in-One w/USB Cable & 4x6 Premium Paper InkJet Printer Logo
651 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
