Question about Indesit Dryers
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
  • Indesit Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 10, 2010
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
Why when my door is open on my indesit idc75
The door switch is probably stuck in the "door closed" position. I presume the light inside also does not turn on.
Oct 05, 2014 | Dryers
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
Indesit idc75
sounds like its a drum glide worn out
Jan 04, 2014 | Dryers
Indesit IDC75 belt change
Your tumble dryer is a little different than I am accustomed to, but there are millions of dryers in the U.S. with the same sort of system. Try this. I think ( I hope) the belt goes as follows:
The small black(?) pulley should be spring loaded, so that you can either push or pull it toward you or away from you. I think the belt goes around the motor shaft first, then goes back around the black pulley, then to the drum up above. When you are done, the belt should be upside down S shaped, with the motor shaft in the bottom of the S and the black pulley in the top of the S. I cannot type an upside down S on this keypad. When you pull or push the loose pulley, it should allow the belt to slip by on one side or the other to go around the back of it.
Be blessed.
Apr 27, 2013 | Dryers
No heat coming from drum when spinning with our indesit idc75 drier can u help? looked for reset butten but cant find one can u please help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 15, 2011 | Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
I have an indesit model g74c tumble dryer,drum turns but no heat,
either your thermostats or your element are faulty, best to find an approved engineer to carry out repairs
Sep 17, 2009 | Dryers
Dryers Logo
795 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
