Question about YouTube Videos
My you tube is not opening properly - YouTube Videos
    President:
  • 2,291 Answers
You have to clear internet cache nad internet histroy and also registry to fix it use reginout cleaner for this
Posted on Oct 11, 2010
Why four barrels do not open 65 4100 carb
The choke linkage is not properly hooked up or adjusted. The throttle linkage is not adjusted properly or there isn't enough vacuum. The choke linkage has a tab that prevents the 4 barrels from opening when the choke is engaged. There is a tab on the throttle linkage from the front 2 barrels that will engage the secondaries when they rotate past a certain point. Vacuum opens the top plates on the secondaries.
Sep 19, 2014 | 1965 Ford Mustang
How to use a metal pendant w/fillable tube?
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 26, 2012 | Cars & Trucks
You tube is not working. wat is solution.
Dear vinmy86263:
If your You tube is not working try to check it to your settings maybe its blocked. Because there is no other way to open it because it can never be installed. Maybe your browser is not properly installed.
Regards,
Angel
Feb 08, 2011 | Microsoft Computers & Internet
Water in the bottom of the freezer that freezes, then the water goes out the door and is messing up my floor. My fridge is a Frigidaire side by side model MRS26LGJ. Yesterday, I cleaned out the freezer and...
The defrost drain located behind the freezer back panel has gotten clogged. You will need to remove the panel to gain proper access to the defrost drain. After removing the ice build up you will have to also clear the tube using boiling water alittle at a time poured into the drain opening. this will open the tube up and gain proper flow again.
Sep 22, 2010 | Frigidaire Refrigerators
Code po401 for check engine light
PO401 Insufficient EGR Flow, valve could be stuck or disconected.
It could very possibly the EGR tubes are clogged or the EGR is not opening or could be DPFE; first i would check the tubes on the DPFE and also clean the EGR tubes and egr it self simple brake clean and a hanger can clean the tubes and spray some in the EGR it also can get gunked up and not move properly.
Hope this help to solve it (remember comment and rated this).
Apr 05, 2010 | 1999 Mercury Sable
The machine is overflowing when you run it with a full load.
Not always. It can be anything from pressure switch value to mixer value not shutting off properly.
Dec 05, 2009 | GE Washing Machines
Simpsom concorde 741 washing machine it does not switch of the water level at the level asked for
Unplug the machine from the power point. Open the top hatch, two screw under the lid (they normally have a plastic cap over them which pulls out). Also two nuts behind the machine, from memory they are a number 7 nut.
Gently lift up the top hatch. You will see a thin tube which runs from the side of the Drum/Tank up to the control panel. Remove tube (it has a spring loaded clip where it joins to the tank. Make sure the tube is not clogged or dirty inside. If it is you need to replace the tube.
If the tube is clean, blow into it. You will hear a clicking noise under the control panel, where the water level dial is. that is your pressure switch.
The pressure switch has an adjustment on it, but it is best not to tamper with it, as if you get it wrong, you will flood your house.
Make sure you refit the tube properly as well.
In most cases though the tube itself gets dirty and the air pressure does not rise up to the pressure switch properly.
Good luck
Ash
Oct 22, 2009 | Washing Machines
Not making ice . LED is flashing properly and put power to the valve in the back of the unit and it pushed water so appearantly something is not tellng the valve to open
Check the short black tube that is above the icemaker fill cup , to see if it is frozen . If so , then the water valve is " seeping " . Not closing completely and letting drops go thru which freezes in the tube . After a while , even if the ice maker calls for water , and the valve opens , it cannot fill the ice maker due to the frozen tube . Turn your freezer temp down , after removing as much ice from the tube as you can ( hair dryer may help ) . May take several days to thaw , since the tube runs between the top freezer liner and the outer cabinet . If not frozen , then the icemaker is bad .
Oct 13, 2009 | KitchenAid KSRU25CR Side by Side...
Crazy a/c
try this first. The aspirator grille is on the instrument panel and looks like a tiny regidter, maybe 1 1/2 inch by 1 inch.
Check for proper connection of the in-car temperature aspirator tube. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Cut a piece of toilet paper or tissue paper about 3.7x3.7 cm (1.5x1.5") (paper towel will not work).
  2. Turn the key on and turn fan speed to HIGH.
  3. Select PANEL or VENT mode.
  4. Place the piece of tissue paper over the aspirator grille opening in the bezel. If aspiration (suction) is present, the tissue paper should stick to the aspirator grille.
  5. Turn the fan OFF. The tissue paper should fall off.
  6. If the tissue paper falls off the aspirator grille while the fan is on HIGH, check that the aspirator tube is properly connected at the right bottom corner of the front heater. The black connector on the white flexible tube should be snapped over the black tube connected to the heater plenum. Also, check for kinks and cuts in the aspirator tube.
May 24, 2009 | 1999 Ford Expedition
YouTube Videos Logo
42 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
