Starts up then cuts out fitted new igniter runs for 10 seconds then cuts out
    Scholar:
  • 146 Answers
Why type of heater or model number of the unit?
Posted on Oct 10, 2010
I drilled out the ignition i did not damage the key cylinder housing i tried the parts truck key lock cylinder but the truck woul not start thevsecurity was tripped and the truck does not roll ove
Is this that Lincoln? No, you don't want to do that, in my opinion, some of those components you want to replace will have to be programmed, so you end up right back with the original problem.
This info for spare key programming.
Turn the ignition to run for 1 second with one of existing keys and then remove.
Within 5 seconds, insert a second existing key, turn to the run for 1 second and then remove.
Within 10 seconds, insert a new cut key, turn to the run position for 1 second.
All 3 keys should be able to start engine.
Sorry, that's all I have.
Oct 26, 2017 | Cars & Trucks
I called myself programming the new keys for my pt cruiser, but,it didnt take. At first it would start and run for a few seconds, now it wont turn over.what did I do wrong and how can I fix this?
Takes the master key to get it started again. The security gives you 3 tries to get the vehicle started, after the third time, it kills the starter.
2002 Chrysler PT Cruiser Note: You must have two valid keys to add a new key to the system.
1. Insert the first valid key into the ignition switch. Turn the ignition switch to the
ON/RUN position for at least three seconds, but no longer than 15 seconds.
Then, Turn the ignition switch to the LOCK position and remove the first key.
2. Insert the second valid key into the ignition switch. Turn the ignition switch to
the ON/RUN position within 15 seconds. After 10 seconds, a chime will sound.
In addition, the Vehicle Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert the new key into the ignition switch. Turn the ignition switch to the
ON/RUN position.within 60 seconds. After 10 seconds, a single chime will
sound. In addition, the Vehicle Security Light will stop flashing. To indicate that
programming is complete, the Vehicle Security Light will turn on again for
seconds and then turn off.
The new key is now programmed. The Remote Keyless Entry transmitter will
also be programmed during this procedure.
Repeat this procedure to program up to eight keys.
Oct 09, 2016 | Cars & Trucks
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
How do I reset the anti theft system in my Blazer after installing a new ignition and key?
You need to have a new key cut using the same blank that fit the truck before. The key blanks have a chip that the computer "reads" to allow the engine to start. There are about 10 different chips.
A locksmith or the dealer should be able to read the old key to find the new blank that matches it.
Dec 02, 2014 | 1999 Chevrolet Blazer
2002 Lincoln Towncar, Audiovox asp901, customer lost her keys and had new ones cut and reprogrammed. Now the remote start will not work. The pats light flashes and it wont start with the remote. I need to...
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Sep 15, 2010 | Audiovox APS901 Car Prestige Remote Start
Replaced ignition switch now car won't stay on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Turn the key on to the run position. Leave it there for 10 minutes. After 10 minutes turn the key off and back on for 10 more. Repeat this one more time. After the third time turn the key off and then try and start the vehicle. This will reset the security system.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most probable problem is the crank sensor. It most likely is not reading correctly on start up. You can best diagnose this problem with a computer scanner if you have one.Check you fuel pressure. It should be 60psi minimum..
Dec 22, 2009 | 2001 Chevrolet Malibu
Car was stolen ignition was ripped out of 2002 grandam, now car won't start with ignition and security light keeps flashing
groan.....gunna need a bit more info. but i'll try. What portion of the ignition was ripped out? The tumbler + switch? If so, you might need to get the car's system resent to recognize that it has a new ignition put in. Sime vehicles have a theft prevention system in place to prevent the vehicle from running if its been hot wired. Your best bet would be to replace the damaged ignition components (You did not mention if you did or not). If it still doesn't work after you have replced all of the ignition components. You can try to reset the vehicle (doesn't work on all) disconnect negative battery terminal and go back into vehicle and press down the brake pedal for about 30 seconds then reconnect battery and try it....good luck, hope this helps
Aug 17, 2009 | 2002 Pontiac Grand Am
I have a 93 Chrysler New yorker 5th Ave. The Anti-Theft was activated, and finally reset, but now the car will crank, but only run for about 10 seconds or so and cuts off. I turn the key off start the car...
I had a Dynasty that did the same thing.I had to replace the computer.
The computer activated but was de-activated by 10 key start attempts.
maybe try this as a temporary fix.
Aug 03, 2009 | 1993 Chrysler New Yorker
My Vespa ET4 looses power when it rains then stalls.
moisture is getting into the CD ignition module or on the soark plug wire
Mar 27, 2009 | Gilera Runner VX 125 Motorcycles
Suzuki GT380 keeps cutting out
Check the igintion coils they may be getting HOT.
Feb 28, 2009 | 1976 Suzuki GT 380
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
