Question about Kids Only Digi Pets Electronic Virtual Pet (Red)
For the Kids Only Digi Pet, how do you turn it off? If it can't be turned off, can it be muted? I've tried adjusting the "Lights" setting, but it still seemed to beep.
You have to put it in pause mode. From the beginning, where your pet is moving around: 1) Press enter 2) Press enter again, at index 3) Press left arrow once,
to pause mode 4) Press enter, at pause 5) Press left arrow once, to on
6) Press enter, at on [now it is paused and muted] 7) Then press enter again
later, to undo your pause and continue playing with your pet.
Posted on Sep 14, 2011
Kenwood krf v73000d mute won't go off
Is there a "tape monitor" button by chance? If this is turned on, it will mute your audio as well.
Mar 22, 2013 | Audio Players & Recorders
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Only the mute button comes on on my digi 002 rack
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
Jan 21, 2011 | Digi 002 Rack FireWire-based Pro Tools LE...
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
2 littlest pet shop nintendo ds games wont start up! kids crying
try cleaning the game and try again it may take a few cleanings
Dec 25, 2008 | Electronic Arts Littlest Pet Shop : Jungle
Digi 002 rack firewire
Hey -
Unplugging the harness and reconnecting only worked for a couple days. It turned out that I had to call digidesign and they sent me a new power harness for free. That fixed it for me.
Jun 01, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi design 002 rack
Is your firewire cable good? Sorry, I know this is obvious.
May 08, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 rack
easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Sep 08, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Kids Only Digi Pets Electronic Virtual Pet (Red) Logo
444 people viewed this question
Top Kids Only Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kids Only Toy Expert? Answer questions, earn points and help others
