Question about Frigidaire GLTF2940ES Front Load Washer
There is no water coming in to machine. How do you check the filter?
  • Frigidaire Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Oct 10, 2010
Hotpoint washing machine wf640 there isn't any water coming through when the rinse cycle is on
could be the filter at the water input location in the back of the machine. Or the screen filter at the spigot-end of the input hose....check both hot and cold. First, turn both hot and cold water off at the wall outlet.
Jan 21, 2015 | Hotpoint Washing Machines
The cold water is not working in my washing machine
Check the supply hose filter, and the filter on the intake of the solenoid. Switch the wires on the solenoid to see if rinse will put hot water into the machine, the contact at the timer may be going bad. While reversed, see if it puts cold water into the wash, that will test the solenoid.
Dec 01, 2013 | Maytag Washing Machines
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
No water coming into Washer
Faulty water valve most likely.
Dec 30, 2012 | Washing Machines
Tap to washing machine is working fine, but water only trickles into the machine when filling. What can I do? Hoover washing machine model 200 MONZL
hi just read your posting.1st remove both inlet hoses from the taps and the machine.Check if there are little filters on the ends of the hoses,They could be blocked.Next check the filters on the water valves.The water valves are where the hoses connect to the machine.If the hose and water valve filters are clean then you will need to replace the water valve.Did you check how much water pressure is coming out of the taps?Please reply on how you got on and with additional information and I am sure I can help you on this problem.Looking forward to your reply.
May 20, 2011 | Hoover Washing Machines
The hot water comes out but the cold water just trickles.
Hi from retired Englishman in SW France, Fri 13;29,
A quick suggestion/check- turn off the cold water feed then remove the cold water pipe from the back of the machine. Inside the piece fitted to the machine you are likely to find a filter. Make sure that is clean and not obstructing the flow. Check at the same time that the water IS coming out of the supply pipe at the right rate before putting it back of course!
If neither the supply nor the filter is the cause the cold water inlet valve in the machine could be at fault.
Hope this helps,
John C
Feb 18, 2011 | GE WBSR3140DW Top Load Washer
How come it will not drain water after running a cycle? The washer makes a noise from the back and it sounds like it's the pump trying to pull the water. But... the water will does not come out. What do I...
First place to check is the drain pump filter. Low and to one side on the front panel is the access to the pump filter,, A small hatch or maybe behind the kick panel.
Unplug electricity to machine.
Make sure the machine has as little water in it as possible, because when you open the drain pump filter any water in the machine will run out.
Lean the machine back against the wall will help contain any water left in the machine.
Unscrew the filter cover and clean. Check that a hairpin or bra wire or coin is not jammed in the pump impeller.
Replace the filter cover and test.. If you aren't able to do this or the pump still won't work, you probably need a serviceman to check it out.. You may need a pump motor replacement
Not a big job
Good luck....Nomess
Aug 07, 2010 | Samsung WF337AA Front Load Washer
Water barely coming out? Assuming there is a clog in the washer
There is a screen at the water inlet valve where the water supply hoses are connected. Look in the end of the hoses.
Sep 16, 2009 | Washing Machines
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
