Question about Panasonic Lumix DMC-LZ2 Digital Camera
Camera turns on, but LCD screen is black
When I turn on the camera, you can read the menu, display board, etc, but you cannot see what you are taking pictures of. It stays black. Any suggestions on how to fix this?
  • 10 more comments
  • simpleecaro May 31, 2008
    I dont have the same camera but the same ting happens to mine. When I turn it on and click the play button to see my pictures, it shows them but I have no idea why i cant see what im taking a picture of, it doesn't even take pictures anymore because of that.
  • Anonymous May 31, 2008
    My camera does the same..Black screen and wont't take pictures.I just checked the owners manual and noticed that Lithium batteries aren't supposed to be used...However they are much better quality than Panasonic.. No sign of leakage...But Panasonic says Im not suppose to use these...Its funny the same thing happened to may daughters camera..An LZ2
    My guess is that (from what I've read) the shuuter spring inside can easily come loose.It is just a matter of taking apart and connecting spring..I'm not ready to do that yet untill all else fails..It would cost as much to have a professional repair it than a new camera,,'So If I can't fix it I'm done pruchasing Panasonic products,,This camera has not been used that much.
  • a1j27l84 Jun 05, 2008
    Same exact problem! I have no idea what to do!
  • Anonymous Jun 26, 2008
    I have an LZ2 camera and I have a black screen as well. I read the owners manual and got to start working for one day and now it does not work again. I repeated what I did before, but no luck.
  • sigruber Jul 31, 2008
    When I turn my camera on I can review the pictures and see the menu options but when I try to take pictures the screen is black
  • Anonymous Aug 24, 2008
    Same problem. Screen is black. Can see pictures already taken, but can't take any pictures.
  • Anonymous Sep 04, 2008
    Have the smae problem.
  • Anonymous Oct 03, 2008
    is this fixable??
  • davegangster Nov 17, 2008
    My camera turns on,the menu comes on if i put it on but the screen is black and it takes pictures like the zoom works fine and the flash goes but no picture comes out.I'm at the stage of smashing it. please help me.thanx.
  • Anonymous Feb 13, 2009
    poor image
  • ganesh gokhale Feb 21, 2009
    I have the same problem with my LZ2. This was earlier not used much. But last month having 2 functions at home used it for taking about 500 snaps.
    By reading above solution of pushing can not find suitable as screen goes blank as soon as I stop pushing , & while pushing canot adjust zoom .
    Please let me know what I do next
  • Anonymous Mar 30, 2009
    I too have this problem, you can see whatever pictures are on the memory card but cant see or take new pictures, the screen stays black. The camera was a gift, but i still think that panasonic should be responsible for a repair that is obviously a manufacturers error
I had this problem with an old camera of my brothers (he got a new one because he believed it to have become a dud). I fixed it a few hours ago, it was a CCD Flex problem (this here is an example of a CCD Flex which I found via google images: http://irfu.cea.fr/Sap/Phys/Sap/Activites/Projets/Megacam/Electronic/images/FlexPlie.jpg). Its a relatively nice camera to open up, this Panasonic Lumix, and it is well made except for the terrible malfunction of the camera because of this CCD Flex.
If you're confident of fixing it (I'd had no real experience fixing cameras before, though have much experience fixing computers and a little circuiting experience) then open it all up, you have to get the front casing off to make it easiest to fix so you must find all the screws to unscrew (including the ones attaching the zoomy-lens-thing to the front casing, hidden under the main circuit board). Then find what is connecting the zoomy-lens-thing to the circuit board (there should be two CCD Flex things (see above for a picture) and they were both orange on mine. I found that the problem was with one of them, the one that has plastic over it. I replaced the double-sided tape on the plastic with new double-sided tape, and took out the black thing holding the CCD Flex into the circuit board and then put the black thing back in whilst putting the CCD Flex back in, pushed it as far as it would go, then put the plastic back onto the circuit board via the double sided tape.
It sounds confusing when you read it, but thats because you haven't seen the inside of this camera yet ;) It'll make perfect sense when you do, and you'll be thinking that you're a hero for fixing this after you've done it. It took me 2 hours roughly, which included getting stuck a few times putting it back together, and finding the problem in the first place. Then I felt all tingly, like I was granted a mass amount of luck, once I turned the thing on and it was a picture straight away.
IF, however, it appears to be the other CCD Flex thats the problem, you should push it in properly, its a much nicer version than the one I had to tamper with.
Ohh, to start off with, you should check that the simple fix written on here actually works (its not really a fix, but a painkiller..) of pushing the bottom of the lens upwards. For me I pushed the lens up and left slightly, and it would come up with picture, or at least flicker a lot (it was a little temperamental), so I decided to fix it properly. If it doesn't flicker at least a little bit when you're fiddling with the lens, then you've probably got a different problem.
The end.
Posted on Feb 11, 2009
Solution: Turn the camera on. Put it into camera mode so the lens opens. Then push up on the underside of the lens, you'll see the screen light up and it can now take pictures. This worked for me for a month or two. The problem is that I have to keep pushing harder and harder to get it to turn on, and now it turns back off as soon as I stop pushing. So I have to get a new camera. This is a widespread problem with this camera. I previously paid Panasonic the $162 to fix the zoom freezing up. I'm not paying again.
Dan
Posted on Oct 27, 2008
And then what - is this fixable? Panasonic wants a flat fee of $161.50 to fix camera, I can buy a new one for that.
Posted on Oct 03, 2008
I had the same problem and I tried the push up on lens and now my camera is working normal again. Thanks !!
Posted on Nov 30, 2012
I had same problem. Tried twisting the inner lens hard and picture came back and so far has stayed on. Not most technical solution and I guess runs risk of permanent damage but better than a camera that doesn't work. Panasonic should be fixing these for free as I for one will not buy again.
Posted on Dec 30, 2008
I have the same exact problem but its not a Panasonic, its a canon power shot. I tried to push the lense but it doesnt work. Are there any other solutions?
Posted on Nov 02, 2008
  • 95 Answers
Shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens.
Posted on May 31, 2008
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
My lcd screen is black
From what I can understand, if the camera is sill able take pictures but is not displaying any thing on the LCD, then it is a problem with the LCD or LCD cable connecting to rest of the camera or LCD driver on main board.
It can be as simple as a loose flexible PCB connection to the camera main board.
' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+70)+"px"; } -->
Jun 20, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Canon EOS 450D Can only get the Shooting Setting Screen no image
In picture taking mode, press the "set" button for "live view".
Feb 27, 2010 | Canon EOS 450D Digital Camera
My camera can play back pics and the zoom moves when I turn it on, but the camera LCD display remains black when I try to take a picture
Look in your menu to check you havnt turned the LCD Screen off as a battery saving option.
If not Take it to be repaired
Oct 06, 2009 | Canon PowerShot SD1000 Digital Camera
LCD display isn't on
In order to turn on Live View, first put the camera in one of the Creative Zone modes (i.e. P, Tv, Av, M or A-DEP). Then press the menu button, and scroll to the second settings menu (the second wrench-symbol), then scroll down to "Live View function settings" and press the SET-button. Then scroll to "Live view shoot", press SET, scroll to "Enable", and press set again. Close the menu by pressing the menu button twice.
Now you can turn on and off the live view on the LCD by pressing the SET-button.
/Chris
Jan 04, 2009 | Canon Digital Rebel / EOS-300D Digital...
Most button don't work
If your button board has kicked the bucket, resetting the camera is not going to help any. This is a repair problem, sorry.
Nov 13, 2008 | Canon PowerShot S5 IS Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Black screen Kodak EasyShare C653 Digital Camera
probably you unable the lcd display function, try hit |0|i button, its upper menu in you camera, also you could try hitting menu button, if lcd comes back and you can see menu, then is not a camera problem, it's a configuration. i recomend you read quick starting guide.
gretts, a.
Oct 16, 2007 | Kodak EasyShare C653 Digital Camera
LCD screen won't show preview except in C mode
Well, after a little more googling, I'm embarrassed to say I've found the solution. I must have somehow pressed the display button which turned the preview display off. I tried pressing all of the buttons before I made my previous post, but apparently i didn't press it. :(
Oct 11, 2007 | Canon PowerShot A630 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
630 people viewed this question
Top Panasonic Cameras Experts
Jay Plesset
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
