Question about Hayward Navigator Pool Cleaner
My ****** sucks but it won't go forward. i had all gears and gear box replaced, shoes, wings, could it be the front flap? when i take off the front flap it moves forward. we borrowed a used loaner from the store and it worked great, so I know its not the filter or pool pump.
  • 990 Answers
You can try "A" frames and a new paddle wheel. If these are bad the suction can be real good and you can get some movement out of the cleaner but as soon as it get's a load on it, it will stop.
Posted on Oct 10, 2010
How to change front power seat track worm in 1993 landcruiser
Lift the front edge of the seat bottom by using the regular power seat switch. Take voltage readings of the seat slide motor.2 Verify that the voltage to the seat slide motor on the harness side between "BR" and "W/B" is 12v when the power seat's switch is pressed backwards and forwards. Jot down your radio presets and tap the seat slide motor so that the motor will work long enough to give you access to the seat mounting bolts.3 Pull the seat as forward as it will go. Take off the two M10 rear seat mounting bolts and set them aside. Push the seat as far back as it will go. Take off the two M10 front seat mounting bolts. Switch the ignition so that it marks "OFF." Unplug the negative battery cable. Stand by for 4 minutes. Raise the seat assembly to find the harness-to-seat connectors. Disconnect them.4 Take out the entire seat assembly and place it on a dry, clean, flat surface. Position it so you can access the bottom of the seat. Undo the seat bottom's carpet flap and take out the four M8 bolts. Then, take out the top screws from the right hand and left hand side finishers. Unplug the seat sub-harness connector.5 Put both the seat rails back into their rear position and take out the worm gears, motor, flexible wire and gear boxes all at the same time. Take out the flexible wire from the gear boxes using a screwdriver. Verify that the new seat track mounting tab makes contact with the rear stopper and that the threaded shaft facing up is point upwards. 6 Install six new rubber grommets. Place the new worm gears, flexible wire and gear boxes into the frame. Reposition the seat tracks over the seat track mounting tabs. Use your hand to tighten the M6 bolts securing the seat track mounting tabs. Torque the six base plate nuts securing the gear boxes to 64 to 85 inch pounds (7.17 to 9.69 Nm) and the M8 bolts on the seat's front edge to 13 to 17 foot pounds (17.5 to 23.7 Nm).7 Plug the slide motor connector back in and hook the carpet flap's strap. Reinstall the seat assembly and reconnect the electrical connectors and negative battery cable. Torque the mounting bolts to 27 to 36 foot pounds (37 to 49 Nm). Operate the seat to make sure that the problem has been resolved
Sep 29, 2011 | 1993 Toyota Land Cruiser
My navigator gets stuck when it encounters the steps. It will not move but flaps around and does not move. I have changed the bearings, the flaps, the feet and have replaced anything else that has worn...
It could be that you have improper water flow. Use the water flow gauge and adjust the flow if necessary. It could also be a steering failure. Check the pool cleaners rear screen and clean it if necessary. Make sure that the cone gear is free and rotates smoothly in both directions. You could also need to replace the gear box.
Jul 06, 2011 | Hayward Navigator Pool Cleaner
Front and rear flaps are not flapping
It is possible that your pool cleaners shoes and/or wings have become worn. If you can see any visible wear and tear, you will need to replace them. If you are referring to the rear tension flap, there is a rear flap adjuster that you will need to loosen.
Apr 09, 2011 | Hayward Navigator Pool Cleaner
Gets stuck behind the ladder
It could be one of several problems with these pool cleaners: check your water flow and adjust if necessary, check for worn shoes and wings, make sure that you have proper hose length, and check for steering failure. Steering failure can be caused by several things. Make sure the rear screen in clean and free of debris. Make sure your cone gear is free and rotates smoothly. Check your gear box and clean or replace if necessary.
Dec 24, 2010 | Hayward Navigator Pool Cleaner
My Hayward Navigator fails to get out of corners and climbs straight up a wall and remains in this positon. I have adjusted the suction flow to no avail.
Check your shoes and wings to make sure that they are not worn and don't have debris lodged in them. Make sure that your hose is the proper length and doesn't have obstructions. It could also be a steering failure. To check for steering failure, make sure that your rear screen is clean, make sure your cone gears are free and clean, and make sure that your gear box is clean and working properly. It is common for these pool cleaners to have one of these problems. Also, make sure that you have the proper tension in your rear flap.
Oct 30, 2010 | Hayward Navigator Pool Cleaner
Only goes counter clockwise
With these pool cleaners, turning in only one direction is most likely the result of a worn shoe or wing. Check them for any wear or tear and replace if necessary. It could also be a partially blocked throat that has restricted suction and is hindering movement. Check and clean your rear screen. Make sure that your cone gear is free and rotates smoothly in all directions. In none of these troubleshooting tips correct the problem, it could be your gear box needing to be replaced.
Oct 22, 2010 | Hayward Navigator Pool Cleaner
Navigator goes in circles
When this problem occurs with these automatic pool cleaners, it is usually an issue with the house having a kink or blockage. I would check that first. If you have, make sure that the wings and shoes are not worn. Make sure the water pressure is not too high. Check the rear screen to make sure that it is clean and not blocked. Check to see that the cone gear is free of obstructions. It might also be the gear box that needs to be replaced.
Jul 25, 2010 | Hayward Navigator Pool Cleaner
My navigator is suctioning however when it hits a wall it simply stays there and won't turn around any more.
With these automatic pool cleaners, it is often a problem with the water flow not being correct. Test your cleaner to make sure that the water flow is coming out properly. Adjust the water flow gauge if necessary. Make sure that the shoes and wings are in good shape and not functioning properly. Make sure that the rear screen if clear or debris. Make sure that the cone gear rotates freely in both directions. If none of these work, you might have to replace your gear box.
Jun 19, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: My Hayward pool cleaner just goes in small circles...
Check all of the following. Ones of these issues is probably causing your pool cleaner to go in circles. Let me know if these soultions don't work and I will be glad to offer more solutions, but I a think one of these might solve your problem:
1. You might not have proper water flow. Too much or too little pressure will cause this to happen. Check the pressure with your flow gauge and adjust if necessary.
2. Check for a partial blockage of the navigator throat. If you have a blockage, it could disrupt the movement of your cleaner. Clear blockage if necessary.
3. Check the shoes and wings. Damage or wear to them can disrupt your patterns of cleaning. If you notice that your shoes or wings are worn, replace them to correct the problem.
4. Check to make sure that your hose is not twisted. It should be clear of kinks, twists, and knots. Untangle if necessary. Laying the hose out in the sun will make it more pliable and easier to untangle if you need to do this.
5. Other things that could cause steering issues: check and clean the rear screen, check to see that the cone gear is is free and rotates smoothly, clean/replace/repair gear box, check pod connection, and check turbine and spindle assembly.
Hope this helps! Let me know if you need clarification or additional help!
May 16, 2010 | Hayward Navigator Pool Cleaner
Navigator only turns one way, twisting up the line
Try one of these soultions. If you try these suggestions and it still doesn't work correctly, let me know and I will offer some different ideas. With this brand of pool cleaners, troubleshooting is usually pretty simple.
1. You might have an improper water flow that is causing your trajectory to falter. To remedy this, check your water flow with a flow gauge and adjust as necessary. If you have too little or too much pressure, you cleaner will not move correctly.
2. Look for a blockage in the navigator throat. If you see one, remove it. A blockage on one side could cause the cleaner to only turn in one direction.
3. Check for worn shoes and wings. Replace if necessary.
4. Check and clean the rear screen.
5. Check to make sure that the gears are clear and they they rotate smoothly in both directions.
6. Clean, repair, or replace the gear box.
7. Check turbine and spindle gear assembly, as well as all connections, and make adjustments as necessary.
May 05, 2010 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
171 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
