Question about Jabra C820s Headphones
Jara C820 Headphone was working correctly but as soon as the noise cancelling feature is turned on, the left headphone emits a high pitched noise when in close proximity to an object such as ear/head or flat hand.
  • 537 Answers
SOURCE: No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Posted on Nov 21, 2007
  • 50 Answers
SOURCE: Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Posted on Jun 20, 2008
  • 11 Answers
SOURCE: Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Posted on Aug 27, 2009
cseian
  • 138 Answers
SOURCE: The sound coming from my right bose on-ear headphones
i think ur headphone wires or its pin at end will be defective..
99%there is no chance of failures in speakers ..
try to replace ur headphone cable with new cable.
just solder the cable with speaker inline pins..
Posted on May 25, 2010
Messic
  • 94 Answers
SOURCE: First i was having issues with the sounds
I would recommend that you do not plug in noise cancelling headphones to the jacks ON your speakers. Plug it in directly to your source and you should not face this problem.
Posted on Mar 08, 2011
Which headphone I should buy Please suggest me a good one.
Would like to know what your max price will be as £600-1000 has some good headphones
Jul 03, 2017 | Audio Players & Recorders
Why wont the left headphone make as much sound as the right?
The headphone could be defect, or the device you did connect it to.
Mar 15, 2015 | LG Electronics Tone Ultra HBS-800...
Headphone mode
Remove the headphone if its a wired one or turn of teh headset if its bluetooth. If the problem still persists then go into settings then sound and look of an option there. If you have an ipad, just turn of the airplay feature.
Oct 27, 2013 | Samsung Televison & Video
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
Songs played on 5742 are in high pitch
Change speaker settings from headphone to desktop speakers and see if thats not the cure. Let me know : expert-tech / SAM
Mar 27, 2012 | Acer TravelMate 5742 156 2G 250
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
When turned on picture fluctuates and emits hig
The high pitched noise is coming from the Tcon board. It is not properly decoding the signal coming form the main board correctly. The only way to fix it is to replace the Tcon board. You might have a hard time coming across the part because Olevia has since gone out of business. Also, usually Tcon boards are not available sepertaly and most manufactures make you purchase the whole LCD panel of which the Tcon is included.
Nov 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Jabra C820s Headphones Logo
57 people viewed this question
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Mister Danger
jeff tilburn
jeff tilburn
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
