Look friend... looks like your Google Phone is REALLY locked-up and very sick. Almost all of the things I am reading are calling for a complete RESET of your phone!
OR
Take it to a pro shop for service if the data is THAT important to you?...
Otherwise try a USB cable to a computer and see IF you can salvage any information that way?
code p 0001 refers to fuel volume regulator control---circuit open===causes ---wiring---regulator control solenoid
the indications are that the solenoid is opening circuit ( breaking the circuit ) and stops working when it gets hot internally
replacing that unit most likely will be the fix for your problem
Power off, then disconnect from the wall plug.This resets the dvd. after five ninutes, reconnect the power and start the combo. Should have 'load' on the display, then open the tray of the dvd.When you close the tray, it will try to 'read' a dvd again.
You mean you locked it and forgot the combo? Or it just refuses to cooperate? My safe is real finicky, it has to be perfect or it doesn't budge. I could give you the combo and you still couldn't get it open.. Anyway, try this, providing you have the combo, turn right 3 or 4 times to clear the dial, stop at the first number, then go back 2 full turns past the first number and stop at the second number, go right again past the second number and stop at the third number, then left till it latches on the last number. If that doesn't work,, try it with your numbers just a digit or 2 off, try one at a time, then try 2, might take a while, but it will be worth it. If you get it open, I would get the back off the dial and confirm the numbers, then right them on a magnet and stick it to the bottom of the safe. Check it out.
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
hello the problem you have is an erratic switch or any interlock switch that it does not permit to open the door due is not finished the cycle ..firs try this after the cd is working push stop and then open door if it fails is out of time ...needs service for realign the cd system.........................saludos
check if the water has completely emptied - maybe the filter needs clearing.
otherwise. switch off mains. take top off. feel down the front of the machine to the door lock. you can usually find the peg and operate it with thumb nail but difficult
i assume you have'nt broken the door handle
Read other postings about the filter housing located underneath the machine. Clean it out first. We had this problem for a while before the machine finally refused to run anymore.
