Question about Ruud UAKA030 Air Conditioner
250lbs on high side and 35lbs on low side
I believe that theres a restriction on the liquid side. The unit was never turned on in the five years it has been on the house.Also there is no receiver drier in the line.
  • 40 Answers
Or low refrigerant. In that case you have a leak.
Posted on Jun 23, 2008
How do you put in 410a into Ac unit
You turn system on to cool setting and run temp down until outside unit comes on. Then you connect your suction side of your gauges to the suction side of your outdoor unit. Next you connect the liquid(high)side of your gauges to the liquid line on your outside unit(the little copper line). Connect the middle hose of your gauges to the 410a drum of refrigerant. Before opening the suction or low pressure side of the gauges you need to turn the drum upside down and turn drum of 410a on. Then you need a temp reading meter and clamp to read the temp of your liquid line(small line). While charging you want to make sure to release refrigerant slowly. The unit should call for a specified subcooling on unit plate. 7 to 10 degrees. You take the liquid line temp and subtract it from saturation temp on the high side of your gauges.(it'll be the pink numbers on the right side of your gauge.
Jun 05, 2013 | Heating & Cooling
Got a 1999 Buick Century, AC stopped working so I filled up the FreOn and it didn't make a difference. Checked all Fuze's and Relays (to the best of my ability) still no change. There are no knobs, it...
Can't see filling with freon without compressor turning. Put jumper wire on high/low pressure switch harness to see if clutch engages. If so, bad high/low switch. If not,check power to high/low harness via fuse,relay, or dash control.Battery voltage applied to compressor if accessible will also engage compressor clutch and read your low side with your fill gauge. 30-35lbs is good
Aug 12, 2010 | Buick Century Cars & Trucks
Do you charge the high or low side of a 1995 Chevy Lumina ac?
The low side, with the engine running and the a/c turned on. Low side pressure should be about 35lbs.
Jun 12, 2010 | 1995 Chevrolet Lumina
A-c warm at idle cool moving down road
may have partial restriction. and while driving down the road the compressor is moving faster and forcing past the restriction. try changing the filters in the a/c line.
Aug 03, 2009 | 2005 Ford Five Hundred
''does a new radiator need refrigerant added to it''
You need to replace the condensor, then take it to a shop to have the a/c system evacuated and recharged to purge moisture because the system was opened. That will cost around $150. You do not need to replace the receiver/dryer/suction accumulator even though they will tell you that you do.
go to car-part.com to find prices of condensor from salvage yards. Page with asterisk on it is the lowest priced part.
The Refrigerant Cycle
During stabilized conditions (air conditioning system shutdown), the refrigerant is in a vaporized state and pressures are equal throughout the system. When the A/C compressor (19703) is in operation it increases pressure on the refrigerant vapor, raising its temperature. The high-pressure and high-temperature vapor is then released into the top of the A/C condenser core (19712).
The A/C condenser core, being close to ambient temperature, causes the refrigerant vapor to condense into a liquid when heat is removed from the refrigerant by ambient air passing over the fins and tubing. The now liquid refrigerant, still at high pressure, exits from the bottom of the A/C condenser core and enters the inlet side of the A/C evaporator core orifice (19D990).
The A/C evaporator core orifice is the restriction in the refrigerant system that creates the high pressure buildup in the A/C evaporator core (19860) and separates the high and low pressure sides of the A/C system. As the liquid refrigerant leaves this restriction, its pressure and boiling point are reduced.
The liquid refrigerant is now at its lowest pressure and temperature. As it passes through the A/C evaporator core, it absorbs heat from the passenger compartment airflow passing over the plate/fin sections of the A/C evaporator core. This addition of heat causes the refrigerant to boil (convert to gas). The now cooler passenger compartment air can no longer support the same humidity level of the warmer air and this excess moisture condenses on the exterior of the evaporator coils and fins and drains outside the vehicle.
The suction accumulator/drier (19C836) is designed to remove moisture from the refrigerant and to prevent any liquid refrigerant that may not have been vaporized in the A/C evaporator core from reaching the A/C compressor. The A/C compressor is designed to pump refrigerant vapor only, as liquid refrigerant will not compress and can damage the A/C compressor.
The refrigerant cycle is now repeated with the A/C compressor again increasing the pressure and temperature of the refrigerant.
The A/C cycling switch (19E561) interrupts compressor operation before the external temperature of the A/C evaporator core gets low enough to cause the condensed water vapor (excess humidity) to turn to ice. It does this by monitoring low side line pressure. It is known that a refrigerant pressure of approximately 210 kPa (30 psi) will yield an operating temperature of 0°C (32°F). The A/C cycling switch controls system operation in an effort to maintain this temperature.
The high side line pressure is also monitored so that A/C compressor operation can be interrupted if system pressure becomes too high.
The A/C compressor pressure relief valve (19D644) will open and vent refrigerant to relieve unusually high system pressure.
Item Part Number Description 1 19E762 A/C charge valve port (low side) 2 19E561 A/C cycling switch 3 19C836 Suction accumulator/drier 4 19703 A/C compressor 5 19D644 A/C compressor pressure relief valve 6 19D594 A/C pressure cut-off switch 7 19E762 A/C charge valve port (high side) 8 19712 A/C condenser core 9 19D990 A/C evaporator core orifice 10 19860 A/C evaporator core 11 — Low pressure vapor 12 — High pressure vapor 13 — Low pressure liquid 14 — High pressure liquid
  1. Connect the R-134a A/C Refrigerant Center to the low- and high-pressure service gauge port valves.
  2. Evacuate the system until the low-pressure gauge reads at least 99.4 kPa (29.5 in-Hg) (vacuum) and as close as 101.1 kPa (30 in-Hg) as possible. Continue to operate the vacuum pump for a minimum of 45 minutes.
  3. Turn off the evacuation pump. Observe the low-pressure gauge for five minutes to make sure that the system vacuum is held. If vacuum is not held for five minutes, leak-test the system, service the leaks, and evacuate the system again.
  4. Correctly oil match the system to verify that the correct amount of refrigerant oil is present in the system. For additional information, refer to Refrigerant Oil Adding in this section.
  5. Charge the system with the specified weight of refrigerant and refrigerant oil.
  6. When no more refrigerant is being drawn into the system, start the engine and select MAX A/C operation. Set the blower motor speed to maximum and allow the remaining refrigerant to be drawn into the system. Continue to add refrigerant into the system until the specified weight of R-134a has been added. Close the charging cylinder valve and allow the system to pull any remaining refrigerant from the hose. When the suction pressure drops to approximately 207 kPa (30 psi), close the charging hose valve.
May 14, 2009 | 1995 Nissan Maxima
Have goodman unit, ac unit running 55 suction, 210 high side. cleaned condenser coils and charge to 10 degrees supercool. suction at 65, discharge 245, why did my discharge go so high
You should have liquid line filter/dryer that maybe restricted or there is a restriction in the orfice inside the evap coil normal operating pressures are 68/ 180
Oct 07, 2008 | Goodman Heating & Cooling
Ruud UAKA030 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
