My screen turns to the left. What do I have to do to fix it and to have a normal viaw again?
How to fix an arcade screen on a big buck hunter safari machine?
If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
Apr 27, 2014 | Video Game Consoles & Games
Problem with windows starting up with blue screen
Update drivers that control your PC. If problem still persists then use a system utility tool like RegInOut, it will fix the following problems in your PC:
  • Application runtime errors
  • Windows crashes
  • Blue Screen of Death (BSOD)/ STOP Errors
  • Automatic system reboots
  • Failure to start your computer
  • Programs refuse to start
Hope it works for you.
Jan 03, 2012 | Coby 10" NBPC1023 Netbook PC
Mac desktop stop at apple loading screen how do i fix this
Try to force quit the Applications
  1. Go to the top right part of the screen and click on the Apple logo.
  2. Click "Force Quit"
  3. Select the Application you are in or all of them and for each click "Force Quit"
If this doesn't work try to restart your iMac
  1. On the back of your iMac locate the power button in the bottom left.
  2. Hold down the button and then the iMac should turn off.
  3. After a minute or so, try to turn the iMac back on again, it should be operating normally.
Mar 23, 2011 | Apple eMac Desktop
So what happened was that i was walking outside and my phone came out of my sweeter on to the floorbut the ground wasnt dirty or wet. (the phone had already fell once that day) i picked it up and looked at...
take it apart and check your flex cable connection, see you tube video for taking your phone apart, easy fix if you have a small screwdriver. Takes about 15 minutes.
Nov 07, 2010 | LG VX5500 Cell Phone
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
When turned on: srm450 has no sound, but all leds (power and signal) is normal. If I turn the volume up (near maximum) , the srm450 sound is activatet again , and peforms normally. I then turn volume down...
1 TAKE THE MAINS PLUG OUT
2 Unscrew the fixing screws on the back. (just the outside ones)
3 Take the back off and turn the amplifier circuit board to face you.
4 About 2" from the left and about 4" from the bottom you will see a sort of tab. pull it off gently and widen the 2 prongs slightly.
5 Put the jumper tab back on and re fit the amp.
Dec 26, 2009 | Mackie SRM-450 System
Screen display is flipped
I simply turned my television off while emailing fixya and reading the user's manual. The television was turned off for about ten minutes. I think what happened was that the dvd skipped while ejecting and caused the screen to flip....who knows, I'm just happy it works properly again because I love to watch movies.
Thanks anyway,
Brett
May 17, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Jeep Liberty Left Rear Turn Signal Not Working
sounds like the bulb you have is the wrong resistance the new noen bulbs will do this
Nov 16, 2008 | 2004 Jeep Wrangler
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
