There is a Black thick strip coming along while scanning what might be the problem
  • 1,110 Answers
Something is stuck on your scanner "glass". This is a small strip of glass about an inch wide that runs from one side of the scanner to the other. If you open the panel where the documents are fed in to be scanned you should be able to see the glass. Sometimes a small flashlight comes in handy. Once you located the strip you can clean it with a cloth that has a bit of glass cleaner sprayed on it in the area you are using. Most of the time a general cleaning will take care of the line. If after cleaning the line does not go away then look at the image of the scanned document and use the original as a guide by placing it the same way in the machine that you placed it originally. The area of the document where the line is being created will guide you to where the area of the scanner glass is creating the line. Concentrate your cleaning effort in that area.
Good Luck and Thank You for using Fixya.
Posted on Oct 10, 2010
In copy mode I am getting a back strip along the left hand side of the copy. The strip also shows up in the preview. Strip used to be half inch thick and is now an inch thick.
Is any part of the image missing under this black strip, or is it just margin from the side of the document to the end of the glass?
If nothing's missing, then probably you set a larger original size in the settings somewhere.
Try a sheet of white paper the size of the glass, put on top of the (smaller) copied picture or document; when scanning it is not a big deal, you can always choose the area to be scanned, right?
If however part of the document is missing, this can mean that the photosensitive element is faulty and doesn't read a couple hundred pixels on that side and the device needs repair.
Oct 27, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black line through the middle of the document
The thick line is either because of dust sticking to the glass or a module problem. Try different brightness settings and scan white paper. If the thickness varies and also the sides of the black strip are jaggered (step like) then it is dust on Glass. use isopropyl alcohol to clean, dont use solvents. If the teickness is same for all levels of brightness and has a sharp edge always, it could be scan module problem.
S. Mohan
Oct 05, 2009 | Canon DR 3080C Path-Through Scanner
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
DOCUMATE 510
check on the flat bed part along the top. there are two white strips that go side to side. the top white strip is wider than the bottom strip right underneath it. On the thinner of the two strips, check for small black marks, can be very small. This creates a black line in the document. You can clean it with a fingernail & a tissue
Jun 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Black Line
Take glass cleaner and clean the small strip of glass to the far right. If there is a speck on that strip of glass it will cause a line when it scans.
May 02, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Black Line on Scanning
Clean scan glass slit near where original is fed, it will have white out/glue on it.
Jan 02, 2008 | Brother MFC-8500 All-In-One Laser Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
69 people viewed this question
k24674
jasbo
jasbo
