Question about HP Pavilion dv9000z Notebook
My hp pavallion 2615tx does not play external audio devices such as tape when conneced through the line in port. the sound mixer does not show any sound devices except speakers. any solution for the problem?
  • 998 Answers
Your sound card is not supported purchase a latest sound card for your notebook
Posted on Oct 10, 2010
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
Mar 09, 2012 | HP Compaq d530 SFF PC Desktop
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
No sound coming from speakers, Showing erra message every time I try to play music showing this message There is a problem with your sound device. "No active mixers available",
Try reinstalling the audio driver.
You can download the audio and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Jul 07, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
I have purchased a peavey pv 6 (not the usb) and I have a squeal problem when I activate the tape to mix button and rising the master fader to 0 and my headphone volume. I am using a creative soundblaster...
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Jun 28, 2011 | Peavey PV6 Mixer
How to install mixer devices
I'm going to assume you mean an audio mixer and maybe an AV receiver.
The connections themselves are fairly simple but it pays to understand what happens in the loop. And since you don't name the EQ I'll make some broad generalizations that you should be able to adapt to your equipment. They're all pretty much the same for hook-up anyway.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the selected stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose some form of STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
It's should be clearly marked on the back of the Mixer where everything goes.
The Line IN and Line Out would go to any available Tape Loop on the receiver. Something that has Out's and In's. Obviously, Out's on one device go to In's on the next.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck or anothere processor you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks and those loops can be engaged or bypassed via controls on the EQ or Processor.
May 15, 2011 | Audio Players & Recorders
How do i connect my technics su7700 amp to my technics sh8020 equaliser
Like any sound processor, in the tape loop...
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec or Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play or Line-Out.
Feb 15, 2011 | Audio Players & Recorders
The external display stays muted and plays no sound but when I use the headphone port the sounds work. I cant get the laptop speakers to produce any sound though.
Go to control panel and go to sound and hardware (Just go to anything that says sound)!
Then go to sound and audio devices!
Go to Audio and change the default until sound comes out of tv!
Aug 28, 2010 | HP Pavilion dv7-1130us laptop
My hp mini 110-1000 has no mixer device
A mini note book is a very restricted device - with plain standard audio hardware - go to HP.com - select software and drivers - put in your product number then select your OS - down load the audio driver package.
Jun 30, 2010 | HP Mini 1000 Netbook
Aardvark pro q-10
Yes, you have to connect the monitor outs to a mixer (or directly to your monitors) to hear. It is a totally separate sound card than what is coming out of your audio out port. Anyway, you'll get much better sound quality from the monitor outs.
Nov 26, 2008 | Aardvark Direct Pro Q10 (bundle) External...
HP Pavilion dv9000z Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
