I have just had the second keyy fall off . That's the letter o and the F1 button. Can I fix myself? get a replacemnt ker or have I to replace the wholw keyboard?
When I type, the hammer does not engage the letter on the print wheel. Is this an easy fix I can do myself?
There is a spacer on the hammer solenoid that falls apart over time. It must be replaced. Any local typewriter repair facility should be able to get and install the part. This is the most common problem on the wheelwriters. The ibm part # is 20-71. It is a little difficult to to do this replacement if you are not a technician. But, it should take no more than 30 minutes to replace and clean the machine
Feb 10, 2015 | IBM Wheelwriter 6 Typewriter
THE OVEN DOESN'T WORK...F1 ERR
You need to replace the clock control
May 20, 2010 | Ovens
I need to clear he bios password in a toshiba satellite pro L40
  1. Remove battery.
  2. Remove memory.
  3. look at the side of the memory at the top left side and locate the little brassy coloured dots with the lettering JRST1 at the side (jumper reset 1).
  4. Touch something metal across them for a few seconds.
  5. thank me because no where on this stupid internet has anyone got a solution to this and I had to find it out on myself.
Good luck, Bowling Crony.
Sep 08, 2009 | Computers & Internet
I HAVE THE PRODUCT CODE KEYY BUT DOESN'T WORK
Contact the dealership ant they ought to give you a valid key for free
Jun 21, 2009 | Microsoft Office Professional 2007 Full...
D52w17 big screen tv won't power on
Thats a common problem which means the Flyback and cp150 and CP114 need replacemnt. Your model used a couple different flyback designs but the following link can tell you which one you need and they provide free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | RCA HD52W59 HDTV Projection Television
If n70 fall down its display not work
your cellphone lcd was damage you change your lcd.
CONQUER CELLPHONE REPAIR
Apr 24, 2009 | Nokia N70 Cellular Phone
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
