Have a Logitech y-tk49 keyboard & a m-rr67a mouise & I am trying to get them to connect, but with no result. I was given these by a computer repair man who is nopw out of business. I do not have a manual. Where do I go from here?
  • umbriago Oct 10, 2010
    I am getting those model numbers right off the keyboard
    The response I posted over an hour ago was "The model numbers came right off the back's of the mouse & keyboard. They are wireless". Am I going to get a further response??????????
  • 4,737 Answers
If I am right, you want to know how to connect your wireless keyboard, but the only keyboard with this model is only ps2 connecting through the KMV switch. Well, I am giving you the instructions on how to connect logitech wireless keybaord and mouse to a computer.
Instructions below:
BATTERIES
1) The Logitech Cordless Mouse & Cordless Optical Mouse both use "AAA" size batteries (1.5 volts). [This is subject to change without notice.]
2) The Logitech Cordless Keyboard uses two "AA" size (penlight) batteries (also 1.5 volts). [This is subject to change without notice.]
3) Be careful when inserting the batteries that you put them in correctly. It is very easy to put them in so that the positive (+) end of the battery is in the negative side ( - ) or vice versa.
4) Be sure to check the batteries periodically with a Battery Checker. You can buy an inexpensive Battery Checker at Radio Shack or at some computer stores that tells you whether the battery is "OK" or if it's time to "Replace" them. Check the batteries before you put them in to be sure you aren't putting in old batteries if they are not coming straight from the box.
5) The batteries normally last about 4 to 6 months with the Logitech Cordless Mouse, and about 2 months with the Logitech Cordless Optical Mouse (the one with the red laser in it and no ball). You should see a window pop up on the screen pop with a warning when the batteries are low.
CONNECTING
1) Push the Connect button on the Receiver (that box that looks like a dark gray pack of cigarettes located on the right side of the monitor).
2) Press the Connect button on the underside of the mouse.
3) Likewise, turn the keyboard over and press the Connect button on the underside of the keyboard.
Note: Some Logitech keyboards have the Connect button on the right side.
4) You will then see a small window pop up in the center of your screen indicating that you are attempting to connect the cordless devices together.
5) Click on the Close or Cancel button to get rid of the small window.
DISTANCE
1) Keep the distance between the Receiver and the Mouse at about 8 to 12 inches. (The maximum distance they can be separated is about 6 feet, but the mouse will usually work better at 8 to 12 inches.)
2) Keep the distance between the Receiver and the Keyboard at about 8 to 12 inches, too.
I hope this helps, if you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 10, 2010
  • 3,530 Answers
You are trying to these two to connect to the computer is that right? Are you sure these are the right part numbers? I tried searching them in google but no results. I wanted to see what the specifics of these two devices so we can start troubleshooting.
What are these devices? Are they USB devices? Or the connectors are round with pins?
If they are not working with your computer, you need to install the drivers so that the computer can recognize them however, like I said, I tried googling the model number you gave me and there is no result. Please make sure that you have the right brand and model numbers so we can look for the drivers.
All the best!
My wireless keyboard will not connect after following the given directions, though it has brand new batteries, and the mouse works fine
have you pressed the connect button underneath the keyboard and on the receiver connected to the computer? in most cases, that does the trick.
Aug 31, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
I have a logitech Ex100 mouse/keyboard set & both have just suddenly stopped working. It tells you how to re-start the system by pressing 'connect' on the reciever & then the mosue &/or...
Do a Hard Reset method to clear the keyboard and mouse settings and reconnect it back to your computer:
• Remove the batteries from the keyboard
• Press the Connect button on the receiver for 10 seconds.
• Press the Connect button on the mouse.
(You might need a pencil tip or other small tip to press the connect button.)
• Insert the batteries back into the keyboard.
• Press the Connect button on the receiver.
• Press the Connect button on the keyboard.
Mar 02, 2010 | Logitech EX100 967499-0403 Keyboard
I have a logitech cordless optical mouse m-rr67a......BUT I DON'T HAVE THE INSTALLATION CD!how can i get cd ?
Depending on the OS version you have, Windows may have a basic drive available in its library.
Turn the mouse on first (either switch or just movement), then boot your system. If you see a message saying it has 'found new hardware' and is installing software for it, you will have basic functions. If you need the entire installation (which may have a more detailed UI), you can get it from the Logitech website.
Nov 22, 2009 | Logitech Cordless Mouse
I have a cordless optical mouse m/n: M-RR67A BUT I DON'T HAVE THE INSTALLATION CD!
have you gone to the logitech website and you already connected the mouse and it does not work? Most of the time your pc will recognize the mouse.
Sep 25, 2009 | Logitech Cordless Mouse
My computer stopped recognizing my wireless keyboard & mouse. Says it's missing a driver or that the device is malfunctioning. Don't think it's a battery prob. Do I need a new driver?...
Uninstall the Keyboard driver.
Unplug the Logitech keyboard.
Restart the computer.
Plug the Logitech keyboard back into the computer.
Windows should recognise the keyboard and/or the mouse.
Place Logitech setup disk in drive.
Reload the drivers...
The drivers sometimes corrupt themselves..
You might download the latest drivers for your keyboard/mouse.
Jun 28, 2009 | Logitech Wireless Access Duo Optical...
Logitech dinovo bluetooth keyboard passkey issue
You entrer your own passkey after hitting the connect button on the KB.
May 28, 2009 | Logitech diNovo Edge Bluetooth® Wireless...
Wireless Keyboard not connecting
I opened up the Logitech Mouse and Keyboard Settings, turned my keyboard off, changed out the batteries and turned it back on. It then detected the Keyboard and asked for a password, I entered in the password, it said it was rebooting it and asked for another password which I entered (both passwords were given to me in the Settings). Now it is working just fine! Not sure if you have tried this but it might work for you.
Jan 04, 2009 | Logitech EasyCall Desktop? Keyboard and...
Logitech keyboard F Lock works but nothing else Connectivity?
Reply to this issue from Logitech Tech Support:
Thank you for contacting Logitech Technical Support. My name is Susan and I will be assisting you with Incident # xxxxxx-xxxxxx .
I understand that the keys on your keyboard are not responding except the F lock key and the battery indicator key. Please correct me if I misunderstood you.
It appears that your keyboard might be encrypted during first installation.
To try and resolve this issue, I would like you to try and decrypt your keyboard. You can refer to the steps below on how to do this:
1. Press Ctrl + Alt +F12 key on the keyboard.
2. Press the Connect button on the receiver.
3. Press the Connect button underneath the keyboard.
4. Press the ESC key on the keyboard.
Once you have performed the steps above, test the keyboard in simple text applications such as Notepad or MS words to verify if the problem persists.
Additionally, you can try the following steps should the steps above was unable to resolve this incident:
a. Press the Connect button on the receiver for 10 seconds.
b. Wait for 20 seconds and then press the Connect button on the receiver again. Press the Connect button on the mouse.
c. Insert fresh new batteries back into the keyboard.
d. Press the Connect button on the receiver.
e. Press the Connect button on the keyboard.
This would help to isolate the cause of the incident that you are experiencing.
If this does not address your question, please update this incident, describing the results after following my suggestions. Or, if you prefer, you can contact us directly by the phone numbers listed below.
Thank you for choosing Logitech.
Sincerely,
Susan
Logitech Customer Support
www.Logitech.com/support
Dec 03, 2008 | Logitech Cordless Desktop EX110
How to make logitech keyboard & mouse work??
Hi there: I was also facing the same problem. But when you see on back of the keyboard the instructions are there. or follow these steps.
1. insert new batteries both in keyboard and mouse. 2. decide what device you want to connect 1st (Lets connect Keyboard first) 3. Pres and Hold the connect button for both key board and receiver for about 5 secs. 4. don't press any key on key board till 10 secs (During this time it trying to connect with receiver) 5. Check the key board connectivity if it works then take it away or put it behind some barrier so that when you are connecting the mouse it don't interrupt. 6. now for the mouse do the same process as you have connected the keyboard.(step 3 & 4) 7. now check both key board and mouse they will work fine. Thanks
Sep 21, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
