Question about Canon PIXMA iP2000 InkJet Printer
Canon ip2200 waste ink absorber is nearly full - what do I do about it? Thanks
ginko
  • 19396 Answers
SOURCE: Waste Ink Absorber full - Canon Pixma
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Posted on Mar 13, 2008
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
SOURCE: canon printer mp160 e27
E27 Waste ink absorber full or platen waste ink absorber full please chek it
Posted on Oct 08, 2008
wanali
how can i get my ink absorber to be unful and work agian so i can print again WANALI
Posted on Oct 11, 2008
SOURCE: waste ink absorber full--where do I get it serviced? or, can I do anything?
in some canon printers, you can look down into the printer, carefully remove the sponge rubber "Absorbrer" wash it under a running tap and very carefully replace it, making sure it is fitting back exactly where it was. I did this twice and then reset the counter using the code above. If you reset too many times without getting rid of the ink, the ink can leak out of the printer. I was quoted $AU65 by a Canon dealer to do this on a $AU99 printer. I bought the new printer same model, with 4 new ink Carts, that sell for $AU22.95 each, and pulled the old one to bits to see what does what!
Posted on Dec 14, 2008
Printer states waste toner absorber nearly full. Action?
You need to call Cannon and order a new waste ink absorber pad.
#732-521-7230 M-F
Mar 02, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Waste ink absorber is full
Hi there
Mar 14, 2010 | Canon PIXMA iP1600 Printer
Ink well transformer full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Waste Ink Absorber Almost Full
Download this utility
Unzip and run GeneralTool.exe
Select the correct USB port
Click lock release and your printer model
Click clear waste ink counter
Select main or platen
The selected waste ink counter will then be reset
Reset both especially if both have been replaced
Sep 01, 2009 | Canon Office Equipment & Supplies
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Canon PIXMA iP2000 InkJet Printer Logo
135 people viewed this question
old marine
old marine
