Question about Car Audio & Video
Wiring harness on my 94 Ranger
I have a 94 Ford Ranger "splash"(cool truck really)that use to have a Pioneer KEHsomething SuperTuner. Someone thought they needed it more than me and took it out.Luckily the left the wire harness' intact. Problem: I bought a wire harness "kit" that had the black connector and the grey connector to put in a lesser Sanyo stereo in. Seems the kit I got had the two connectors reverse of what the truck's is. Now I need to know what color wire does what on the power/ground side of the connector setup. Of course my handy Chilton's is of no use in that dept. Please help as I aM GOING CRAZY LISTENING TO ALL THE SOUNDS MY TRUCK MAKES@!!!!!!
  • splash45 Jun 02, 2008
    ok! I just got my response and I will update if we have a winner!!
    thanks FIXITKC, i'll let you know
I have a 94 Ranger XLT extended cab. Here are the power/ ground connector pinouts and wire colors as shown in the factory service manual:
Pin 1 LG/Y Radio Memory Power (B+)
Pin 2 BK Ground
Pin 3 Y/BK Power (Hot in RUN or ACCY)
Pin 4 LB/R Illumination (dims with dash lights)
Pin 5 O/BK Illumination (does not dim)
Pin 6 BK/LG Ground
From the diagrams, looks like either ground will work.
Hope this helps.
Posted on Jun 01, 2008
Engine caught on fire need wiring harness and diagram for a 1993 Ford Splash Ranger
Check with a salvage yard or do a used part search online. Ford doesn't have a complete diagram, it is broken down into sections of the wiring harness. you need the factory wiring diagram booklet, you can often find them on ebay.
Apr 03, 2016 | Ford Cars & Trucks
I need wiring schematic for starting on a 96 ford ranger 3.0
Thank you for the year,make and model with the engine size, this make it easier for me to help you with the correct info.
Wiring diagram for a 1996 ford ranger , splash with 3.0 engine.
Here is the starting system wiring diagram. Hope this is helpful good day.3_18_2012_3_06_28_pm.gif
Mar 18, 2012 | 1991 Ford Ranger Supercab
94 Ford Ranger starting problems
I would check the coolant temp sensor.
Mar 10, 2010 | 1994 Ford Ranger Supercab
Need to tighten the serpentine belt on a 1994 ford ranger with 2.3L 4 cyl engine
There is an automatic belt tensioner on your vehicle designed to take up any slack.
If you are having problems with the belt slipping the tensioner spring may be weak/seized/worn. Also you may need a new belt if the rubber has gone hard and cracked.
There is also a technical service bulletin on this truck regarding water splashing up on the belt and pulleys. Ford bulletin No. 94-18-8 speaks of installing a splash shield. You will need to see your local Ford shop to get this part.
Hope your repair goes well.
Nov 27, 2009 | 1994 Ford Ranger Supercab
I have a 94 ford ramger the fuse box under neath
for a wiring diagram you could go to autozone and get one from alldata. also try to find someone that has the same vehicle and check it out and take some pictures.
Oct 31, 2009 | 1994 Ford Ranger Supercab
95 FORD RANGER NO INST. PANEL LIGHTS AND PARKING LAMPS
you might have blowed blulbs check that also there might be what is called a fuse link in the wiring
Mar 15, 2009 | 1995 Ford Ranger Supercab
Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
Sep 01, 2007 | Pioneer DEH-P690UB CD Player
Car Audio & Video Logo
524 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
