Question about Tomtom ONE LE Car GPS Receiver
Hi, My TOMTOM ONE does not recognize its SD card; I think It's not the slot as when the card is out it asks for it, but when it's in there's just an alert-symbol showing the SD cancelled in red... I got this machine from a friend, I don't think he still has a backup . The card is 241 Mo full of files, from a Win-explorer" point of view all seems OK . What should I do ?? Many thanks.
  • dmeckert Oct 13, 2010
    Exact, the lock-slide was just a bit moved down a half mm, I just had to push it correctly and all is working fine. (and your explanations are very very clear and complete)
    Many thanks.
    Genius:
  • 1,456 Answers
Hello there
The memory card may be locked and that has made it unreadable,to unlock your SD card please do the following;
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to the next step.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet.
Try the card in your computer, using the USB converter stick. If the items on the SD card are available, copy them to your computer as a precaution. If that did not solve the problem, proceed to next Step
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side. If you are actually trying to unlock a micro or mini SD card, proceed to next Step
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card. Micro and mini cards do not have switches. Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data. SD Adapters look very much like SD cards and the switch works the same way.
If this does not solve the problem then the memory card is corrupt and should be reformatted to do that;
Insert the into your SD card reader on a system.
Right-click "Start." Click "Explore."
Right-click the SD card. Click "Format."
Choose the "FAT32" file system from the drop down menu and click "Start" to reformat the corrupt card.
This should solve the problem.
Posted on Oct 10, 2010
Tomtom Go920 device is not recognized by computer
every time you want to connect it to your computer you should reset it, see on the bottom there is a small hole for this purpose, then connect it...good luck
Feb 06, 2010 | Tomtom GO 920 GPS Receiver
Unable to connect device to computor, and my sd card has been erased.tried to do back up but no success please help
First, do you have the maps on your computer? in tomtom home? if so reset your device by inserting a clip into the small hole next to the sd card slot and hold for 15 seconds then start your tomtom home programme on your computer and connect your device, click yes when asked and then click manage my device in tomtom tick the map(s) you want to transfer and then click copy too device, hoping this helps
Feb 06, 2010 | Tomtom ONE GPS Receiver
TomTom Go 500 doesn't recognize SD cardq
Tom Tom does not recognize the maps you download because they are not from them. Priority controlled.
Jul 23, 2017 | Tomtom Go Plus GPS Receiver
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
Device not recognized by computer
Lots of folks having this problem with many different TomTom Models, mine was with a GO630.
Do a "reset" on the unit, use a paperclip or somesuch and hold the reset button on your TomTom in for about 5 seconds, and the unit will rrset and will be recognized by your computer.
Jun 28, 2008 | Tomtom GO 920 GPS Receiver
Reformat sd card for tomtom one
FIRST THING , Backup the SD card. To format an SD card you insert SD card into card reader slot on a PC or a SD card reader. Then find the SD card Icon in 'my computer'. Then hover over it with the mouse and right click , choose 'format' from that drop-down menue. REMEMBER .... EVERYTHING ON THE CARD WILL BE DELETED ! *** WARNING *** The card will not work in the tomtom once it has been formatted.
Jun 05, 2008 | Tomtom ONE GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Max. Mem. Card
I think you will find that the tomtom one 3rd edition is a sealed unit.
No SD slot.
But it does have 1GB of RAM for storage and 32MB RAM for system use.
Pretty much the same internal architecture as an early handheld PC.
All updates are done through USB.
Hope this information is useful.
Feb 26, 2008 | Tomtom ONE GPS Receiver
Slot
The Slot in the base of your Tom Tom is for the SD Card. This is where your maps are stored. No SD Card no maps. Hope this helps
Nov 30, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE LE Car GPS Receiver Logo
350 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
