Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Max hard drive that can be fitted to a dell dimension 5150 thanks tom
  • 570 Answers
Sir your Dell dimension 5150 can be expanded with maximum 250 GB of hard drive .
Thanks.
Have great day.
Posted on Oct 10, 2010
How can I remove hard disc from dimension 5150
Check out Dell's support documentation, found here:
http://support.feelpcs.com/pc-spec/DimensionE510/parts1.htm#wp1366406
This shows how to remove and add a hard drive to the Dell Dimension E510/5150 series.
Here's a YouTube video showing you how to add an extra hard drive to your system. The process is quite similar, except you would just unplug your SATA and power cable, grip the two blue plastic tabs, and pull the drive out.
https://www.youtube.com/watch?v=xVaBB8X6KhQ
Hope this helps!
Aug 24, 2014 | Dell Dimension Computers & Internet
What size hard drive goes into a dell 5150
this site will give you the build list for the computer. you can put any size hard drive in it you want as long as you stick with IDE type
http://support.dell.com/support/edocs/systems/dim5150/en/sm/specs1.htm
this means you can not use the newer SATA drives. has to be IDE
Jun 20, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 won't load drivers
Hi try going to control panel, system, hard ware and then device manager. If you have any driver issues, your device will be highlighted by a yellow ? With your driver CD in drive, click the + sign and right click the device with the problem, select update driver, follow instructions and select install driver from disk. Hope this helps
Jul 16, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dimensions 5150 and want to add more disk space. What is largest size hard disk i can add and is there a thickness issue to bear in mind
technically there is no specific size limit ..currently the max. avaiable for home use is 1.5TB ...(LARGEST) hard drive
your model can surely fit in 500 gb of disk space...(again it all depends if u would be needs so much ) i leave that for u to decide .
assuming to dont have big video cards , that may cramp the internal space , i am sure anything under 500 gig should easily fit in ...
good luck
Oct 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Need to add extra bays
Have you used any spare 5.25 in bays yet?.....the wider ones at the top when the optical drives live? .... you can get 5.25 to 3.5 in side rails to fit to hard drives so they fit in them.
Dec 31, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension 5150 dvd rw stopped working
Open the computer and reseat all of the connectors, and memories.
if the machine is full of dust and dirt, then you need some compress air to clean them out. power supply, under the motherboard, hard drive, floppy drive.
flashing yellow lights means that either the Hard drive is not starting up or the momories is not present.
Aug 13, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
122 people viewed this question
Alun Cox
