Question about Aiwa PX-E860 Turntable
How do I remove the turntable to replace the belt underneath - I have just purchased the turntable and the belt is loose.
    Guru:
  • 256 Answers
Good day. I assume that you have lifted the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsHow do I remove the turntable to replace the belt - micmor100.jpg
Posted on Mar 18, 2011
How to remove the turntable plate
At the base of the spindle of the turntable is a c-clip. Use a table knife or flat screwdriver and needle-nosed pliers to carefully remove it. The turntable can be lifted off. Take care to not damage the belt underneath, if a belt-drive turntable.
If luck is with you, all it needs is a thorough cleaning.
Jan 17, 2013 | Microwave Ovens
Have a turntable not turning . model SL-20A
hi,
Check the belt of your turntable. If the belt get loose or broken this type of complaint can occur. Watch the following video. It will give you the information , how to remove and replace the belt.
ok
Apr 11, 2011 | Technics Audio Players & Recorders
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
I have a Pioneer PL-61 turntable I plugged it in and put the speed on both 45 & 33, with no movement. Any ideas? It was given to me by a friend
Take the turntable off. Check the motor to see if it's turning. Clean the shaft with alcohol and wipe the alcohol residue off. Make sure the drive belt fits tightly. If it's loose, it will slip.
Oct 16, 2009 | Audio Players & Recorders
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
JVC turntable LA10
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Mar 16, 2008 | Audio Players & Recorders
Turntable drive belt replacement
7) That's it.
- OPTiC
MasterTech
Nov 27, 2007 | GPX S7799 Shelf System
Aiwa PX-E860 Turntable Logo
131 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
