Question about Bosch Exxcel WFO 2264 Front Load Washer
The warning sign of the Key has come on together with the double circle sign. The machine will not start as a result. What is the problem please.?
  • diana_jurado Oct 10, 2010
    You are correct. Resolved itself immediately. Many thanks for your assistnace. Very much appreciated. Diana
    Yes thankyou! Already passed on my thanks to Rylee.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the controls are locked and to unlock you'll need to press and hold the TEMP and OPTION button for 10-15 seconds. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 10, 2010
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
How to put in an =sign in the calculator? Is it the double arrow button above the enter sign? LOST!
On most calculators, the equal sign role is played by the ENTER key. When the key is pressed, the calculator performs the calculation and displays the result.
Nov 08, 2015 | Office Equipment & Supplies
Have board game parcheesi but no instructions can you help?
Instructions
    • 1 Place four groups of pieces, or pawns, on their respective color circles at each corner of the board. The first player rolls the dice. When the dice has a five, or the two die combine to make five, the player can move one of his pawns out of his circle.
    • 2 Move pawns in a counterclockwise direction. You can only move your pawns on the purple and light blue squares in this game.
    • 3 Roll again if you roll a double. However, rolling doubles a third time forfeits the turn and the pawn furthest along the board must be moved back to the starting circle. Rolling a double when all the player's pawns are out of the starting circle is a "double bonus" and allows the player to move by both the tops and bottoms of the dice.
    • 4 Count each die separately. For instance, if a 2 and a 3 are rolled, the player can move one pawn two spaces and another pawn three spaces. If the same pawn is moved, it is not a total of five spaces moved, but two and then three; if another player's pawns are on a square two or three spaces ahead, the player cannot move.
    • 5 "Bop" the other player if you land on a square occupied by another player by exact count; the other player then must start again. It also allows you to move your pawn other 20 squares.
    • 6 Complete a circuit around the board in order to enter your pawn into the corresponding color home row. You can only reach the center square by an exact count. You then earn ten extra points that another pawn can use.
    • 7 Get all four pawns into their corresponding color finishing squares to win the game.
Tips & Warnings
  • Each square in the main ring and in the home rows can only have none, one or two pawns on it. The two pawns must be of the same color.
  • Purple squares are safety squares. A safety square cannot be occupied by two opposing pawns. One pawn on a safety square does not create a blockade, so other colors can pass by it.
  • Two same-colored pawns on a space form a blockade, or barrier. A blockade cannot be passed by any other pawn , even one of the same color. A blockade cannot be moved together. (This rule only affects doubles.) A blockade must open when the player rolls a six.
May 22, 2011 | Toys
Oil change warning sign need to be reset
scroll through the diagnostics using the up and down arrow in the right side of the radio till you reach the percentage of oil left then hold the CLR button which is the circle inbetween those arrows till it resets.
Jun 21, 2010 | 2003 Cadillac CTS
What does the warning lamp displayed as a double
Brake ware warning light.
Brake pads have sensors , when pads worn out to the point when it needs to be replaced , sensor gets cut by brake disc and light goes on.
Jun 05, 2010 | 1994 Mercedes-Benz S-Class
How do I convert from decimal degrees to degrees, minutes, and seconds?
You have a key, the label of which is the degree sign, the apostrophe and the double quotation mark. It is located between the change sign key (-) and the [HYP] key.
To enter an angle with degrees, minutes and seconds you use the key to separate between numbers
Ex: 18 deg 0' 45" you press 18 [Deg ' "] 0 [Deg ' "]45 [Deg ' "] [=] As you type the calculator displays 18 deg 0 deg 45 deg but the result will show correctly. You have to press the key after the seconds figure, otherwise you get a syntax error.
While the foregoing result is still in answer memory, if you press the [Deg ' "] key the result will be displayed in decimal degrees.
The key is used to enter the DMS values and also to toggle between DMS and D.D.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Degrees seconds and minutes
Sorry, text was posted as clarification request. Here it is
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
The symbol is a round orange circle with ! sign inside and lines
Brake pads require checking
This warns you early so you don,t ruin discs
Dec 24, 2009 | 2007 Mercedes-Benz SLK280 Roadster...
Dashboard warning --circle with exclamation point
the sign which is shown can you properly define it weather it is a brake sign or some thing or different without proper explanation no body would be able to solve your problem sir
you do one thing better confirm what sign it is or simply it is better you refer to your owner manual booklet for further clarification if still are confused than better to visit to nearest authorized workshop or service station.
till the next time i solve your queries this siddhanth saying bye for now have happy motoring & safe drive
Oct 04, 2009 | 2008 Mazda Mazda3 Hatchback
Bosch Exxcel WFO 2264 Front Load Washer Logo
288 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
