Question about Cameras
My camera turned its self on in the case and now when i turn it on it wont focous!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 10, 2010
Self timer stuck
hello
Have you tried turning the drive mode lever from self timer mode to single shot mode? If not, surrounding the mode dial are a couple of levers: one being the on and off lever and the other being the drive mode lever. if you move the drive mode lever up to the first option (illustrated by a single box, meaning single shot), you'll be able to turn the self timer off.
If that doesn't work, then it might be a system bug/error. In that case, download the latest firmware here and upgrade your camera.
Hope this helps!
May 11, 2012 | Panasonic Lumix DMC-G1K Digital Camera...
Camera wont turn on
your lens is not interacting with the power sequence if you turn turn on the camera and the message is displayed (switich the camera of and on again) then its mean that your camera lens is pressed either by your self or accidently the lens housing is malfanctioning
Feb 29, 2012 | Sanyo Xacti S650 Digital Camera
I have a problem with my wide angle Sony HVR-Z7U when i record
so its blurry when u r filming?? if it is may be you are using wide adapter then some of them you cant really zoom much with without loosing focous..and they take sometime to adjust focous
Feb 24, 2012 | Sony HVR-Z7U DV Camcorder
My Panasonic Lumix DMC-FX150 is giving me a SYSTEM ERROR (FOCUS) message as of last night. It says, ''turn off the camera and turn on'' but of course that doesn't do anything. And I've removed the...
I'm not sure if you've gotten this resolved, you probably have - however, others will find this useful. When I left my memory card out the camera worked fine but when I would insert the memory card again, poof: "SYSTEM ERROR (FOCUS)." You can take your memory card to most photo places, even Costco/Walgreens, and ask them to reset your card. It doesn't erase the pictures on there but it does a reset/reboot to the card. Anyhow, I hope this helps. Good luck!
Apr 11, 2010 | Cameras
The focus is blurred and when you use the zoom it still will not focus. My camera is a Konica Minota Dimage Z3 4.0 mega pixels.
lens including the focousing unit must be serviced,while u focous press click button half way till u get green led glow,then click.
Apr 09, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
What is the case when a ps3 shuts off in the middle of a game and wont turn back on
if the power indicator was flashing red and green probably means it was overheating. if thats the case it either fried its self or turned its self off. let it rest for an hour then try and turn it back on if it doesnt turn on its probably fried
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
Sd550 wont focus even if you depress knob halfway in
focousing unit of the camers lens unit has to be serviced/replaced with a new one
Feb 28, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Makes noises at start up and wont allow me to take pictures.
lens assembly has got knocked out of time . the noise is the gears slipping . needs lens assembly .
Feb 03, 2009 | Casio Exilim EXZ75 Digital Camera
Blurry picture
hi ,i cant help at this moment.but! banging it is as bad as dropping it, who told you that, light tap may help! looks to me like your lens is jamed and can not turn and focous this is a very pricece job bin or sell as spares. the picture blur could be a fault in the very fine leeds that run the camera.....
Sep 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Wont turn on
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Mar 18, 2008 | Kodak EasyShare C533 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
