Question about Nokia N77 Cellular Phone
All the buttons in my keypad is not working - Nokia N77 Cellular Phone
Only the power button works
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Jul 25, 2012 | Samsung SCH-u740 Cellular Phone
My GTB3410 sometimes the three buttons below the touch is not working alternatively, some times call button is not working at the same the back and end button is working , some times end button is not...
unscrew your phone and remove the keypad. then try pressing the phone without the keypad, if it works very well it means you will have to buy another keypad for your phone.
May 12, 2011 | Cell Phones
The down button the numbers 2, 3 and end call button have stopped working. when i press one of these buttons its shutting the phone down-any ideas or advice please?
Hi, it's the keypad IC or the keypad itself. So you can check the keypad if there is dirts that is stopping the keypad from working. Or the keypad needs to be replaced.
After checking the keypad if the keypad still did not solve the problem,
You will have to replace the keypad IC inside the board of the phone.
Take care. .
Aug 20, 2010 | Sony Ericsson K850i Mobile Phone
Some buttons of keypad not working
this should be most probably because your soft pad below the keypad had been worn.So you can change this pad so your keypad will function normal.
Jul 21, 2010 | Nokia 1600 Cellular Phone
My se p990i flip keypad malfunction
It has a flex/ribbon inside the flip keypad,you must replace it or the whole flip k-pad.
Jul 22, 2009 | Sony Cell Phones
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad doesn't work onlt the on/off button
hmmmm... maybe a one of the side buttons is stuck up..try pressing them if all side buttons click, if not then there's your problem
Jan 24, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Razr Keypad
It is a humidity issue. I had the same problem with my phone. I baked it in the oven on the lowest setting for 20-30 minutes and it works fine now :)
Sep 06, 2007 | Cell Phones
Nokia N77 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
