Question about RCA CC6151 Camcorder
No Display I haven't used my camera in a while. It has been kept very clean and safe. Having charged my battery per instructions I am unable to see anything in the viewfinder. The cap is removed, the power button by the thumb button shows read (on) I can hear the tape moving if I play, rewind etc. I can hear the camcorder when I zoom in/out. I just can't see anything when it's on. The Tally light is also not on. If I use the DC charger to operate and not the battery it's the same issue. Can you please help? Your expertise is appreciated
Underneath the black battery, when you take it off to charge, there is another small battery compartment it holds a round battery about an inch in diameter. try replacing it. that might be the problem. hope it works out for you.
Posted on Jun 16, 2008
My lcd screen is blank as soon as i turn it on and it want do anything
I can't find manual, but I try to help you anyway.
On lots of digital cameras there is a power safe function. If you put the camera in power safe, the display will not go on. Sometimes it is just the display button on the back of the camera. A little button with an arrow to the right.
Please check in the menu's.
Then there is this nasty thing called battery. The battery (Batteries) can come fresh from the charger, that indicated the battery is charged and still the battery does not have enough power to let the camera work. Try charging the battery again and if you have a spare use that one. Even if you don't use the camera, make it a habit to take out the batteries and charge them at least 2 but better 4 times a year. Off course always charge the battery short before you use the camera.
Jan 02, 2014 | Sanyo VPC-S7 Digital Camera
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
OBJECT ERROR RESTART CAMERA
If you did not obstruct the lens, would think there is a battery problem. Digital cameras require lots of power. As you call on it to do more things like extending the lens and focusing the power requirement goes up.
I had a similar problem with my camera and finally discovered that the problem was with the battery to camera electrical connections. I cleaned the contacts as described in the source link about two months ago and have not had a problem since.
The following excerpts came from the source link. Hope this helps!
Most cameras will reset to original settings if batteries are removed for at least one minute. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
The secret to making digital cameras work better is having good electrical contacts between the batteries and the camera.
Digital cameras require lots of power. If electrical contacts are not really good, this can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD display is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. With bad contacts, cameras do strange things like making bad pictures or shutting off with the lens out.
To prevent overcharge, use an automatic two or more hour battery charger with safety timer, temperature monitor and trickle charge technology ($9.78). For longer life, NiMH batteries should be charged often and kept in active use. To preserve battery charge, use the view finder and not the LCD display when possible. Maximum capacity is reached after 2 to 4 charge/discharge cycles.
http://www.google.com/base/a/4210404/D13...
Mar 13, 2011 | Canon PowerShot SX100 IS Digital Camera
My D80 is suddenly dead. I was uploading photos to my computer yesterday. After most of them were uploaded, an error message popped up saying an error kept it from uploading the next one. It kept popping...
This is why the pros always use a card reader instead of the camera. When you disconnected the camera, did you remember to use the "safely remove hardware" function? The computer was obviously still trying to write and communicate with the camera and if you just disconnected it, the camera became corrupted. Check your manual for instructions for a camera reset. Try that. Also, remove the card and batteries, press every button, leave it alone for 20 minutes, insert the card and then the batteries, turn it on. Sometimes this works.
Oct 10, 2010 | Nikon D80 Digital Camera
Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
4. Upload new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11888/11893&product=EKN034495
If successful please give me the feedback as a rating or recommendation. Thank You
Jan 01, 2010 | Kodak Easyshare C813 Digital Camera
My cybershott70 won't turn on
Dear Sir,
The problem could be with your camera to battery connections. The
Digital cameras require lots of power. If electrical contacts are not really good, this can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD display is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. With bad contacts, cameras do strange things like making bad pictures or shutting off with the lens out. For cleaning procedure you may visit this link http://www.google.com/base/a/4210404/D13701973093918363271
Aug 27, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Camera will not turn on
It may help to remove the batteries for a few minutes or clean the contacts. Repair of cameras is more expensive than replacement, but it may help to clean and charge the batteries as described below.A friend asked me to clean and charge her new 2000mAh Duracell batteries as described in the next link. Those batteries are still going strong after four months of normal use and have not been recharged.Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. http://www.google.com/base/a/4210404/D13...Also, digital cameras reset to original settings if batteries are removed for one minute. Time varies with function/camera. Check display/setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged/cleaned batteries and restart camera. The ultimate non-physical repair for software-using devices is reset by removing power ... VCR/DVD players one month.Most NiMH rechargeable batteries lose charge and should be recharged when not used after two weeks, but Duracell and RayOVac new formula 2000mAh NiMH batteries hold charge one year when not used. Also, 2000mAh batteries seem to have a longer life. Did not like these batteries at first, but have 12 over five years old and all are still as good as new. Higher mAh batteries (about one year old) still work well in flashlights, but won't start my camera.CAUTION Do not overcharge! Batteries can be damaged. Use an automatic two or more hour Energizer Compact smart charger with temperature monitor, trickle charge technology, and safety timer ($9.76) at Walmart. Use pre-charged 2000mAh Duracell ($12.97) or RayOVac ($5.97) batteries (both hold charge one year) and a full cycle charge. To preserve battery charge, use the viewfinder.If batteries are removed more than a few hours, the date/time setting and other set-up information will be lost. If the camera is being stored for a long time, the batteries should be removed and stored properly.Carry and dispose of batteries in baggies, blister packs, or other containers to protect ends from short circuit. Batteries explode when short circuited. NiMH batteries are environmentally friendly and may be discarded with trash.The next link is about prolonging the life of lithium-based batteries which last from two to three years, but are very expensive. A Sony series G rechargeable 960mAh lithium-ion battery is $49.88 at Walmart.http://www.batteryuniversity.com/parttwo... ...Camera reports batteries low, but is it low charge or bad electrical contacts? Overcharging can ruin good batteries! The secret to making digital cameras work better is having good electrical contacts between batteries and camera.Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but camera will indicate "low" if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out. NiMH batteries should be recharged when camera reports batteries low. Old batteries can discharge over night, but may provide normal service immediately after being charged. Battery pairs no longer usable in cameras may work well in flashlights. Do not drop batteries or allow voltage below one volt.CAUTION To prevent memory card corruption, keep batteries charged, format in camera, and don't delete or fill card completely. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select, then click Stop and OK.Never touch battery ends or camera electrical contacts. Oil from fingers will contaminate contacts. Use batteries in matched pairs of same brand and rating. Do not mix old and new batteries. New will only do as well as old.Click source link for other camera tips and complete instructions on cleaning camera and battery electrical contacts.
Apr 10, 2009 | Kodak EasyShare C743 Digital Camera
RCA CC6151 Camcorder Logo
77 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
