Sound like you could of solved a misfire hows the cranking does it sound smooth example ta-ta-ta-tataaa-ta-ta-ta-taaa-ta, that would be a low compression cylinder, recheck the firing order
you update wrong version. always take system data printout from "ready tech" and report menu.
there shows firmwire version.and after that you flash the exact crack firmwire.
for any help you can call me on this number : 9437082724.
AVAYA KUMAR SAHU.
Model TA-4570 has been discontinued for some time and is no longer available. You can still purchase model TA-3050 as a factory refurbished unit. The only real difference between the TA-4570 and the TA-3050 is that the 4570 is a cord or cordless model whereas the 3050 is a rechargeable model only
You will find model TA-3050 at shaveroutlet.com. See link below
There is quite a bit of speculation on how to determine this. The following site will give you some insight: http://my.malloc.us/silverspring/2008/08/clarification-of-new-ta-088-models/ . If it is to load custom firmware, there is no harm in trying the pandora battery. It does not brick the v3 PSP. It just does not work. I tried it myself. Hope it helps.
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
