Question about Neff B1421 Electric Single Oven
Need fitting instructions to replace door hinges as manual misplaced. thank you.
    President:
  • 1,140 Answers
The user manual probably wont have instructions for replacing your door hinges anyway. The service manual would, but they don't generally supply those with the oven.
I'd need to know the brand and model of your oven in order to give advice on fitting, as would any other expert here. Some ovens have sprung tension hinges, others have pivot/swing hinges.
Posted on Oct 16, 2010
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
How do you fit an oven door to a Hotpoint BD81P oven? My hinges need replacing ?
Go to
WWW.YOUTUBE.CO.UK
In the search box enter---FITTING OVEN DOOR HINGES
You will find some very informative videos on how to fit the hinges.
Dec 04, 2010 | Hotpoint Ovens
Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
I need to take the door off - any ideas
A lot depends on the type of hinges fitted to your oven door.
Try this link, it should help you .www.youtube.co.uk
In the search box type, replacing oven door hinges
Please let me know if you were successful .
Thanks.
Barkencoa
Nov 25, 2009 | Whirlpool RBS305PD Electric Single Oven
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Dec 22, 2008 | Ovens
Replace door hinges
I had exactly the same problem until tonight!
I had nothing to lose so solved it by sheer brute force!
The problem is with the hinges that the door clips into they seem to get very loose. If you can manage to crimp them against metal they won't move and your door will shut properly. This is how I did it.
1. There are a couple of locks (levers) on each hinge open them up and then lift off the door
2. Ensure that there is nothing wrong with the door brackets, tighten the screws on them to ensure they don't move.
3. Fit the door back on to the hinges and with the levers still open(towards the door) push the door against the hinges which bends them tight in position (don't push too hard otherwise you will completely bend the bracket out of shape you just need to do it enough to crimp it in to place and prevent it from moving)
4. Now open the door, push the levers back closed against the hinges and then shut the door. Hopefully it will be a much tighter fit.
Nov 26, 2007 | Electrolux EOG6330 Gas Single Oven
Neff B1421 Electric Single Oven Logo
525 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
