Question about Olympus SP-510 UZ Digital Camera
Having laptop with win 7 home; when connecting camera through usb, system gives me a message, that driver for device SP510UZ is missing; consequently i can not read from camera as drive it is not listed at all; why? as far as i know, everything should go automaticaly - plug & play as before in XP many thanks in advance
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 29, 2011
Lost Live TV after windows 7 Utimate system reinstall
is the usb connector and aerial all connected properly?
did the device driver install properly?
is ur computer PICKING UP ur Aerial and usb connector device?
is it classified as "Unknown" in device manager?
-- Uninstall ur TV Drivers, Reinstall ur TV Drivers, Restart ur computer, check all the use cables DONT use any usb adapters that would require more power for the usb and aerial. (i,e, use 1 single port not a 3 port adapter with the aerial attached) MAKE SURE its away from anything magnetic or electrical (fridges, tvs, radios)
Try again. if it worked before theres no reason why it shouldnt work now, think about what u have done differently -- how could it affect it now? how could that make a difference?
if nothing. its probably just ur drivers.
Mar 16, 2014 | HP Pavilion dv9260nr Notebook
Had win8 went back to win7
Drivers can be found here:
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-15-3521
You probably need the Network & Chipset drivers, but make sure you get the right ones for your model.
Nov 05, 2013 | Microsoft Windows 7 Home Premium for PC
You need to format the disk ....
The drives can be read by another computer, so the problem is most likely with OS/drivers on the HP giving the error. The specific drivers required to read each drive format could be missing/corrupt. Formatting shouldn't be performed on a drive that contains data unless backed up (redundantly). It may be possible to recover any lost data using free recovery software. Often a format preserves data, erases only the file directory.
I would try a system restore on the HP. If that fails to correct it install or upgrade format specific drivers (e.g. SD/SDXC drivers). Contact Magellan about the GPS: you may have formatted the device's system partition. It is unlikely your computer had the correct drivers to format that device, and it is likely formatted in an incompatible format (such as NTFS). Does Magellan provide a utility to read the device's memory? The SD card should be salvageable by formatting on another computer using the appropriate formatting utility. (Go to https://www.sdcard.org and navigate to their formatting utility.)
From that site: "If an SDXC memory card is used through the direct SD slot of a computer without SDXC driver installation, the card may not be recognized correctly and a message to prompt formatting may appear. In this case, do not format the SDXC memory card. It may erase the data on the SDXC memory card and format the card for a different file system, making it incompatible with SDXC devices."
Aug 24, 2013 | HP G60-235DX Notebook
Base system missing
Is this in Device Manager? Did you notice this after the Win 7 upgrade? If so , it's a common problen when upgrading, Is that the only issue? Your Card Reader work? Modem? Co-processor? I have a HP Pavilion DV9320us I loaded Win 7 64bit Ultimate on with similar issues, modem, co-processor, card reader, etc. Use the Win Vista drivers, modify the drivers for Win 7. HP drivers found here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0001&lc=en&product=3548477& AND change compatibility of drivers , This will give you the general idea: http://www.techsupportforum.com/4478-installing-a-device-driver-under-compatibility-mode-in-windows-7/
Jan 08, 2013 | HP Pavilion DV9610US Notebook
How do I solve the problem of corrupt or missing drivers
for which Operating System? 98se and millenium edition are obsolete. win xp pro and above are still good.
what device are you having problems with? usb? sound card? video card? or other device? or is it just missing some DLL files from the operating system?
there is also another issue with win xp pro and srv pak 3 it forces the only "signed drivers only" to be installed!! therefore if you have srv pack 3 installed then you will need to to the computer to install any ways. windows 7 will not install "un-signed device drivers" this makes most your devices incompatible with win 7!!
there is another with windows systems up-grades that do not include any kind of driver support except for basic motherboard devices and limited sound cards and video cards and usb port support.
you may want to check your computer maker for any device drivers for the last 3 years only and if it was a device that came with your computer.
Aug 22, 2011 | Computers & Internet
My laptop has no sound. After formatting it and re-installing windows 7 ultimate, it does not sense USB and has no sound. The message i get get is no audio device is installed. How can you help me to have...
Since you just installed WIN 7, I suggest you check the device manager first.
You can do this by clicking on the start button "Orb" then type in device manager, it should show up immediately.
Then you can check there what drivers you're missing, it should show up with a yellow question mark.
From there, you can right click on the said device and you should have an option to "Update Driver".
This should work if you have an active internet on the computer.
Also, this should help if you cannot do that..
http://driverscollection.com/?H=Satellite%20L505D-LS5010&By=Toshiba
Just download the drivers into your desktop screen and then install them one by one.
The sound driver should work as soon as you install the correct driver.
If you have more questions, you can just ask here.
Thanks,
Oliver
Aug 03, 2011 | Toshiba Satellite L505D-LS5010 Notebook
Msi l1350d web cam wont show up its almost as if its not there! looked on msi website they say the driver is not downloadable
Press the F6 Button - this will install the webcam driver. Give it a few seconds untill the "Device Driver Installed Successfully" message comes up, and the camera should work
May 01, 2011 | MSI L1350D-1672US Netbook
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Trying to install the USB driver for a Pentax S4 camera on Win 7
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 10, 2010 | Pentax Optio S4 Digital Camera
Netopia Wireless USB Card
Download this tool driverupdate us and update all of your missing drivers in couple of clicks. I'm using it many years, and it works fine.
take a look
Aug 09, 2008 | Netopia 3-D Reach (TER/GUSB-N1)...
Olympus SP-510 UZ Digital Camera Logo
56 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
