Question about Harman Kardon HK206 Computer Speakers
There is no sound from my speakers green light on
  • 98 Answers
You have to install sound driver software to that supports your pc motherboard... then restart it will work...
Posted on Nov 02, 2010
    Genius:
  • 1,456 Answers
Hello
If no sound is coming from the computer, start troubleshooting your problem. Make sure both your computer and speakers are plugged in, have power, and are turned on. If the speakers are plugged in but do not appear to have any power, plug them into a different outlet. If you are using a power strip and this is case, replace the power strip. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
Once you have verified that you have power to your speakers, test the sound again. If you still do not have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8" TRS cable) is plugged into the green audio output jack on the PC.
Before we move to software, let's try two more hardware fixes. If you are using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you are using outlet powered speakers and have a working set handy, replace the non-working speakers with the working pair to test. If you still have nothing, let's move on to software. But one tip first: (for geeks and beginners)
As it is with any troubleshooting process, the issue can sometimes come down to the hardware itself. If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. If you've been messing around in the BIOS, you may have disabled your on-board sound if that's what you're using. If you don't know what BIOS means, you probably haven't been there and can move on.
Go to your desktop. Click Start > Control Panel > Sounds and Audio Devices > Volume tab. If the "Mute" box is checked, un-check it. In "Device Volume" make sure that your volume level is set to a comfortable volume level for your speakers.
Click the "Sounds" tab. Under "Sound Scheme" check to see if "No Sounds" is selected. If it is, click "Sound Schemes" and a drop down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. These will be indicated by a small speaker icon located next to them. Simply left click the sound once, then click the play button. If you hear sound, congratulations. If not, move on.
Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Try this fix for reinstalling drivers. Click Start > Right-click "My Computer" > select "Properties" from the drop-down menu > Click the "Hardware" tab and then click the "Device Manager" button. Device Manager will open.
Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers" If you have a red X, right click the device with the x and select "Enable" from the pop-up menu. Test your sound at this point. If you have a yellow question mark, right click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Now, click the button "Roll Back Driver" to go back to the previous drivers that were functioning correctly. Restart your computer at the prompt.
As a last resort, you can uninstall and reinstall the device. Right click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If after doing all of the steps, listed here and you still cannot hear any sound from your computer speakers, contact a qualified computer technician. Then get a cup of coffee. :)
Posted on Oct 10, 2010
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Green light is on but no sound coming out of speakers but green bar is moving in control panel/speakers/playback Can't figure out what to try next
Try using headphones in the socket that the speakers are connected to. If you hear sound on the headphones then the socket is working. If no sound then check you are using the correct socket - usually coloured lght green.
Feb 24, 2011 | Logitech LS11 Speaker 2 Speakers
Need color codes for 1995 ford explorer with premium sound system. Ive found my constant, ground, switched, and memory i need the color codes for the other harness
For 1995 Ford Explorer Car Stereo check this Wiring Diagram...
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Good luck.
Jul 07, 2010 | 1995 Ford Explorer
I need an instruction manual to hook the speakers to my computer
There are no manuals for speakers. Speaker wires are color coded. Computer sound cards are likewise color coded.
the light green sound card mini plug port is where the green speaker wire is plugged in.
Pink is for microphone.
Black and orange sound card ports are for additional speakers.
Jun 28, 2010 | Boston Acoustics BA790 Computer Speakers
How do i hook up the speaker to my computer
if you have stereo speakers, connect it to the green audio port on your computer. if you have digital surround, you have green, yellow and black. insert the speaker connectors accordingly.
Mar 14, 2010 | Acer Aspire T310 PC Desktop
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Jan 13, 2010 | Car Audio & Video
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
No sound coming out of speakers green light on speakers is on
The BA 735 Speakers I have are purely digital and will only work if your soundcard has a digital output, will not work through the normal analogue green socket .
Jun 19, 2009 | Boston Acoustics BA735 Computer Speakers
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Sep 29, 2008 | 1996 Ford Explorer
Harman Kardon HK206 Computer Speakers Logo
628 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
