Sumervision customer service cyclone micro medier player sum100603664 had to change setings as in manual.to try to get it to play no 50inch tv playes on 20inch now I can not open tool box to change setings back
bmwrider
  • 215 Answers
SOURCE: Hooking up external DVD player
If you only have the one Audio/Video or AV input then pop into a TV store and buy a cheap AV switch. Plug your Dish Box into one set of inputs and your DVD into the other. Then run another lead from the switch box to the TVs AV inputs. That way all you do is match the switch to whatever it is you want to watch. If your TV does have two AV inputs just run each unit to a set of inputs and change the TV to AV1 or AV2 depending on which you want to watch and which unit is connected to which AV input. I hope you understood that :-) BMW
Posted on May 27, 2006
  • 173 Answers
SOURCE: Change NAT to open
The ports should be opened only in the router not in the x.box, go to a working pc..
To allow traffic from the internet to enter your local network, you will need to open up ports or the router will block the request.
Because our routers use NAT (Network Address Translation), you can only open a specific port or ports to one computer at a time. For example: If you have 2 web servers on your network, you cannot open port 80 to both computers. You will need to configure 1 of the web servers to use port 81. Now you can open port 80 to the first computer and then open port 81 to the other computer.
  • Step 1 Open your web browser and enter the IP address of your D-Link router (192.168.0.1). Enter username (admin) and your password (blank by default).
    Step 2 Click on the Advanced tab at the top and then click Virtual Server on the left side.
    Step 3 Check Enabled to activate entry.
    Step 4 Enter a name for your virtual server entry.
    Step 5 Next to Private IP, enter the IP address of the computer on your local network that you want to allow the incoming service to.
  • to check ip in your pc.. go to start menu click run.. type cmd and hit ok
  • in the black window enter ipconfig and hit enter, you will find the ip address
    Step 6 Choose Protocol Type - either TCP, UDP, or both. If you are not sure, select both.
    Step 7 Enter the port information next to Private Port and Public Port. The private and public ports are usually the same. The public port is the port seen from the WAN side, and the private port is the port being used by the application on the computer within your local network.
    Step 8 Enter the Schedule information.
    Step 9 Click Apply and then click Continue.
  • This would fix your problem..
    Posted on Nov 16, 2007
    • 11 Answers
    Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
    Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
    Enter the xbox's ip address and click the enable box.
    Click apply.
    Your NAT will now be OPEN!
    Cheers!
    Posted on Jul 18, 2008
    • 71 Answers
    First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
    Posted on Mar 15, 2009
    • 159 Answers
    SOURCE: APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
    What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
    • i'd test the dvd/vcr in a different tv
    • i'd test the tv with a different dvd
    i would start over again the installation after this test.
    the reason is to know if you can trust in those sets and second maybe with some other try the installation works
    Posted on May 02, 2009
    It is not playing any dvd's. It says invalid or
    Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
    1. Ensure the Easy Setup procedure has been completed on the BD player.
    NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
    2. Ensure the inserted disc is compatible with the BD player.
    NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
    3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step.
    NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
    4. Use a soft cloth to clean the disc.
    5. Examine the disc for any cracks or scratches that might be interfering with playback.
    6. Attempt to play another disc.
    NOTE: If another disc plays in the player, then the previous disc may be faulty. In this case, contact the Customer Information Service Center at 800-222-7669 to speak with a customer service representative for further troubleshooting.
    7. Remove the disc from the BD player.
    8. Turn off the BD player.
    9. Unplug the power cord of the BD player from the electrical outlet.
    10. Let the player remain without power for 1 minute.
    11. Plug the power cord back into the electrical outlet.
    12. Turn on the BD player.
    13. Insert the disc into the BD player.
    14. Attempt to play the disc.
    If the issue is not resolved even after performing these steps, then try installing the latest Firmware update if you have not done yet.
    Here is the link to download and install the Firmware update.
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS360
    Select the correct Operating System and download the Firmware update.
    Then follow the instruction on the same to install the update in the Player.
    If the issue is not resolved even after installing the update, then Playe may require service.
    Jul 21, 2010 | Sony BDP-S360 DVD Player
    My mother-in-law has a Polaroid HDTV woth built-in
    I can help you with your Polaroid HDTV.
    If the DVD doesn't start when you place it in the player, look for the Play button on the remote control. There may be a TV/DVD switch on the remote that would need to be changed to DVD.
    If the manual below doesn't match your TV, please post the model number of your Polaroid HDTV/DVD combo for more specific help.
    I hope that helps.
    ________________________________________
    Polaroid FLM-2632 Manual Download
    Polaroid FLM-2632 Service Manual Download
    Apr 04, 2010 | Polaroid FLM-2632 Television
    Dvd playing blue picture
    if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
    Jan 11, 2009 | Samsung Televison & Video
    Tv built-in dvd player wont play thru surround sound
    goto your menue setings and slect sround sound and set up to external sound system.
    Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
    TV won't playback DVD-RW Disc recorded on another TV.
    THE PLAYER IN THIS MODEL DOES NOT READ DVD+ OR DVD- OR DVD RW DISKS ITS NOT GOING TO HAPPEN! CHEAP PLAYER INSIDE WILL ONLY PLAY STORE BOUGHT DVDS
    Nov 23, 2008 | TruTech PLV16320 Television
    Dubbing VHS to DVD
    You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
    Oct 10, 2008 | LG RC199H DVD Recorder/VCR
    Phillips SA1100MP3
    Your file format is incorrect. Mp3 playery only use fat32 or fat they wont play ntfs its just a seting on your puter. how are you transfering them to your player. windows media player 11?
    Jan 16, 2008 | Philips SA1100 MP3 Player
    Old tv samsung
    try to check your audio video chord check it if it is open. you didnt mention if your tv has video channel (tuner). if your tv video channel is o.k then the problem of your tv is in the video switcher inputs. in this case you need a service technician.
    Mar 05, 2007 | Samsung TX-P3264 32" TV
    Computers & Internet Logo
    109 people viewed this question
    David Payne
    David Payne
