Question about Dell E172FP 17" LCD Flat Panel Monitor
Hello, I try to fix my DELL E172FP monitor but i'm stopped in my repair because mybacklight is ok but no display. I have scoped vga signals I can trace them until mini-lvds integrated circuit (UC 101) on the LM170E01-A5K8 assy. +5Vdc and + 3,3Vdc are present on the VGA input board and lcd assy. I have tested all SOT23 transistors, diodes and smd inductors. All seems to be OK. All the square IC's have +3,3Vdc. When I unplug VGA cord, I don't get the color bars test pattern. I can only act on brightness with + and - buttons but no menu or something else. The power led is green when on.Thanks to tell me what should I have to verify.
CoachTim
  • 202 Answers
SOURCE: no power in dell e173fpf
I would expect the same (new) part failed. Try another dual diode otherwise you may be chasing the problem around the board.. Good Luck, Tim
Posted on Feb 21, 2007
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
SOURCE: Monitor Flashes Colors when system powered down
Looks like the Burn-in mode is turned on. See here:
http://www.dellcommunity.com/supportforums/board/message?board.id=dim_monitor&message.id=70187
Cecil Thomas
Posted on Jan 14, 2008
SOURCE: Dell 1703ft (17" UltraSharp LCD) powers on, but no picture
Hi
I have dell E172FPb model LCD monitor , the first problem was it blink yellow led and the screen was blank . I open the monitor and i got the two transistors c5707 was shorted , then after i changed the failed component it worked good for a month and so , but after one month the same components have failed again , I tried to find the other components that might cause the failure of the transistors on the inverter board but i didn't get any, then I changed the failed transistors .now the new problem is the power button is blinks green but no image on the screen
is there any help
Abebe
Posted on Feb 15, 2008
vincent721
  • 240 Answers
SOURCE: My E172fp has a blank screen...when i unplug and
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Posted on Mar 13, 2009
What is vga/dvi cables
VGA and DVI is in the way the video signals travel. VGA connectors and cables carry analog signals while DVI can carry both analog and digital. DVI is newer and offers better, sharper display compared to VGA. You can easily tell them apart because VGA connectors (and ports) are blue while DVI connectors are white. Click the link below to see an image of them.
http://www.hardwaresecrets.com/imageview.php?image=8131
May 28, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
Hello, I have a 12.1-inch Dell Inspiron Mini netbook, and I was wondering if I can contact it to Dell flat screen monitor?
Depending upon the model, it looks like many of the Dell Inspiron Mini's have a VGA output and will accept an external monitor. Look for a 15 Pin VGA connector on the rear or side of the mini. If you provide a specific model of mini, I can verify 100% if it will accept an external monitor.
Sep 12, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor stops displaying after a few minutes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
The picture board on your monitor is malfunctioning, since the power led or button is on and it randomly stop the dispaly signals, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 29, 2010 | HP w1907 LCD Monitor
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Can you set up two Dell E172FP 17" flat panel LCD monitors with an latitude D630 docking station?
Yes, but you will need a dvi to vga adapter.
Or one of the monitor must have a dvi input.
Mar 09, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172fp
Replacing the back light?
Are you sure that is the problem?
I didn't see any display with a broken back light. It's more likely the inverter driver is the issue. A back light is assembled with the display and it's really difficult to replace it.
If you confirm that is the inverter the problem, here is a link that explain how to fix it: http://josepino.com/?howto-repair-dell
Good luck
Feb 27, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP shows image for one second
There is a loosing on the Display portion of its circuit, there could be a problem in the Power Supply too. Will need to get it fixed from some repair shop, or if you are ready to get the list of tools, then I can guide where exactly you should try to solder it, or check the desolded items by the DMM (Digital Multi Meter)
Jan 27, 2009 | Computers & Internet
Dell E172FP 17" LCD Flat Panel Monitor Logo
146 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
