Question about Canon PIXMA MP210 Photo All-In-One Printer
Spooler missing I downloaded something that delted the spooler on my canon printer. Part of the message say the printe rin offline.The download also took my sound. Can you help? Thanks .Janie
    Novelist:
  • 85 Answers
Hi
Try removing BOTH cables from printer for at least 1 minute.
Many printers will reset to factory settings.
Otherwise switch off printer and remove printer driver then reinstall it.
Good Luck
Tinteiros (Ebay)
Posted on May 30, 2008
Canon MP210 not functioning
Check Device and Printers in Contol Panel then check if your printer appears in there. If it is not present, something has gone wrong with the drivers. What you need to do now is to reinstall the driver. And it can be found on this link
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210?selectedName=DriversAndSoftware
Once on this page, select the operating system of your computer. Check if its windows vista, windows 7 or windows xp. After that hit the download button. Just run the drivers once the download completes.
Nov 12, 2011 | Canon PIXMA® MP210 Printer
Print spooler offline error message when installing drivers from
Go to control panel on windows!Click on administrative tools and click on services!Go to print spooler and start it again!Good Luck!
Apr 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Dec 03, 2009 | Dell 1700n Laser Printer
Canon Printer Installation
The print spooler is located in services. Start, run,(type) services.msc, then ok. Double click print spooler and start the service. Also look under the dependency tab and make sure all dependent services are running.
Sep 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Print Spooler Problem
In Printer Properties choose PRINT DIRECTLY TO PRINTER
Feb 03, 2009 | Brother Multi-Function Center MFC-240C...
Spooler is not running
Once you install the Printer CD, it will automatically tunn on the Print Spooler service, printer drivers have a Batch file inside it which will allow computer to turn it on automatically when you install printer CD or Downloaded drivers.....
Nov 07, 2008 | Canon LBP 1120 Laser Printer
Canon MP810 printer will not print documents, messages come up on screen: printer not responding, printer offline, document failed to print. Other capabilities are fine.
Hi, there is a possibility that the printer is set off-line or there is a pending print job that was stucked in queue. To check that please go to printer & faxes, right click on the printer icon (your printer), cancel all documents and click yes. Then right click again on the printer icon then select use printer on line. Try printing. If issue still present, restart prinrt spooler services. To access print spooler, goto control panel then administrative tools then select services. Scroll down the vertical scroll bar until select print spooler. Open it then click on stop then start. Try printing again.
Tirzo
Jun 12, 2008 | Cannon Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
http://www.usa.canon.com/consumer/controller?act=DownloadDetailAct&fcategoryid=357&modelid=10238 Above is the Canon site with the newest drivers available. Download them and install them. First "delete" the printer from print properties. Unplug the printer from the wall for a few minutes and shutdown the computer. Plug the printer in and reboot the machine. Install the new drivers. You are in a loop. definition of LOOP: see LOOP. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
97 people viewed this question
old marine
old marine
