Simpson eziset 605 stops with 20 minutes left to go then flashes HC what is happening
3 Suggested Answers
  • 343 Answers
SOURCE: Hi, my Simpson eziset 605 doesn't hold any water.
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Posted on Apr 20, 2010
rickead1
  • 1998 Answers
SOURCE: my simpson eziset 605 6kg
Usually when a washing machine overfills this is usually a sign that the pressure switch has shorted or has a fault or that the hose leading off the pressure switch that connects to the tub either has some debris or soap build up in the hose itself which would also cause the unit to overfill as well if the hose were blocked with debris on the side that connects to the tub. It is the pressure switch that tells the control that the level of water is full enough to begin a cycle. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again
Rick
p.s also assure that the hose is connected to the tub if the hose that comes from the pressure switch were not to be connected and had came off where it plugs into the tub this could also cause the machine to overfill as well. I await your reply if you have any further questions.
Posted on Aug 23, 2011
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson EZISET 605 top load washing machine stopped spinning sound like its spinning but the tub does not spin hence does not wash
I am not sure but it sounds like the rubber/plastic drive coupler between the motor and trans is out. simple repair
Feb 21, 2014 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Oct 03, 2010 | Washing Machines
Hi, my Simpson eziset 605 doesn't hold any water. It fills and drains straight out then flashes and beeps HC on the display. Any ideas why?
Apr 19, 2010 | Washing Machines
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
