Question about Samsung Televison & Video
The TV has started saying check fan1 and the every 1 minutes or so it turns off. What do I do? Where are the fans? Model umver LA40A750RIFXXY
  • Samsung Master
  • 11,800 Answers
The fans are inside the tv - they are used to cool the power source and Y-sus boards. That error message appears because the first fan has failed, the tv overheats and shuts down.
You must take the back cover from the tv off, locate, unplug and remove the fans, and finally clean everything in there with a soft brush. Go with them to an IT shop and ask for an identical replacement - they're standard parts that are found in most of the desktops and will cost you less than $20 both.
Now all you will have to do is to put the new ones in and assemble the tv.
Posted on Oct 10, 2010
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
50 inches LG PLASMA TV TURNS OFF AFTER 15 MIN.
A blown capacitor might not be the reason. After 15 to 20 minutes of work, the temperature inside the set do rises much, this kind of fault can occur. Check its cooling fans.
Jun 25, 2013 | LG 50PT350 50 in. Plasma TV
Will not turn on and says "check 2nd fan"
Thats indicating that the number 2 fan needs replacment. You can get the fan for your model from www.tvrepairworld.com under the Samsung cooling fan category.
Aug 20, 2011 | Samsung HL-S5087W DLP TV
A message on the tv says check fan # 2, then the tv goes off after about 1 minute to 5 minutes.
defective fan causing shutdown. Fans run around $70. A tech will know what to do.
May 27, 2010 | Samsung HL-S6187W 61 in. HDTV
32" 32lc7d after a few minutes, flickers, then goes dark.
There are no fans in this model but it looks like either the backlights in the screen are breaking down after they have warmed up or a problem in the inverter board, again part of the driver circuit breaking down after a period of time. They inverter boards can sometimes be replaced seperatly but usually come with a new screen which if the backlights are at fault then the screen would need to be replaced.
Feb 04, 2010 | LG 32LC7D Television
I replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
Dec 09, 2009 | Samsung HL-S6188W 61" HDTV
Mitsubishi DLP overheating
check your air intake filters, it's a removeable filter in the air inlets.
May 04, 2008 | Televison & Video
Hitachi TV Model 43FDX10B
open it up get dust all out clean it well ok then ya use fans around it vented area to keep it cool its getting to hot dust build up
Jan 28, 2008 | Hitachi 43FDX01B TV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
