Question about PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres
Lan adapter The Lan adapter don't fix.In the manual it says IEEE 802.3 NVIDIA MAC for 100BASE-T fast Ethernet/Ethernet. When I try to install the controller, thee answer is "there is not hardware for this controller". Thank You. Jairo
    President:
  • 2,351 Answers
Juda2008, please tell me how this came about? Where you installing windows? (Fresh install)? Did the NVIDIA LAN driver function before? Or did you just loose the ability to connect to the internet one day & tried to re-install the driver. Than windows reported there is no hardware for this controller? If this is the case, double check in you're bios, page 32. Make sure you're onboard LAN is set to, Enabled. If it is set to Enabled & you are unable to install the correct driver software for the LAN controller, than the onboard controller may be defective. If this board is still under warranty through PC Chips, suggest you call tech support for an RMA. If you're board is not longer under warranty than buy a PCI LAN network 10/100 card. http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=402915&Sku=N100-1420%20P&SRCCODE=CNETFEED&CMP=OTC-CNETFEED
There is one other way to try to install the controller for you're board. Go to PC Chips web site & download the NIC driver software. Create a folder on you're desktop & name it. Click on this link, download the NVIDIA Ethernet Driver into you're folder. http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=392&DetailName=Driver&MenuID=7&LanID=2
The driver file name, Nividia_33nm.zip must be uncompressed. Do this within the folder on you're desktop. Now open device manager. Find the yellow ! point for the missing driver. Right click once on the ! point & slide up to & left click update driver. Windows hardware wizard will open. Click No, not at this time & than click the next button. In the next window, click Install from a list or specific location (Advanced), than click the next button.
In the next window, click on the green check mark next to; Search removable media (floppy, CD-ROM...).
This will remove the green check mark. Than click the Browse button. Go to you're desktop & open the folder you created.
Click on the folder NVIDIA so it is highlighted, than click OK.
Windows should install the NVIDIA Ethernet Driver software.
If you receive the same error message from windows than you're NIC controller is defective.
Mike
Posted on May 31, 2008
How much GB does the toshiba satellite have?
Here is the specifications of the Toshiba Satellite A65-S126
  • Built-in Devices Wireless LAN antenna , Stereo speakers
  • Width 13.5 in
  • Depth 11.1 in
  • Height 2.1 in
  • Weight 7.7 lbs
  • Localization United States
  • Notebook type Desktop replacement (7.5 + lbs.)
  • Wireless capabilities IEEE 802.11g , IEEE 802.11b
  • Processor
  • Processor Intel Celeron 2.8 GHz
  • Data Bus Speed 400.0 MHz
  • Chipset Type ATI Mobility Radeon 7000 IGP
  • Cache Memory
  • Type L2 cache
  • Installed Size 128.0 KB
  • RAM
  • Installed Size 256.0 MB / 1.25 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor SO DIMM 200-pin
  • Configuration Features Provided memory is soldered
  • Storage Controller
  • Storage controller type IDE
  • Storage
  • Floppy Drive None
  • Hard Drive 60.0 GB - 4200.0 rpm
  • Hard drive type Portable
  • Optical Storage (2nd)
  • 2nd optical storage type None
  • Optical Storage
  • Type CD-RW / DVD-ROM combo
  • Read Speed 24x (CD) / 8x (DVD)
  • Write Speed 16x
  • Rewrite Speed 4x
  • Display
  • Display Type 15.0 in TFT active matrix
  • Max Resolution 1024 x 768 ( XGA )
  • Widescreen Display No
  • Color Support 24-bit (16.7 million colors)
  • Video
  • Graphics Processor / Vendor ATI Mobility Radeon 7000 IGP Shared video memory (UMA)
  • Audio
  • Audio Output Sound card
  • Audio Codec Realtek ALC250
  • Compliant Standards DirectMusic , DirectSound , DirectSound3D
  • Audio Input None
  • Input Device(s)
  • Input device type Keyboard , Touchpad
  • Telecom
  • Modem Fax / modem
  • Max Transfer Rate 56.0 Kbps
  • Protocols & Specifications ITU V.92
  • Networking
  • Networking Network adapter
  • Wireless LAN Supported Yes
  • Data Link Protocol Ethernet , Fast Ethernet , IEEE 802.11g , IEEE 802.11b
  • Compliant Standards IEEE 802.11b , IEEE 802.11g
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 (total) / 1.0 (free) x PC Card - SO DIMM 200-pin , 1.0 (total) / 1.0 (free) x Memory - Type II
  • Interfaces 1.0 x Headphones - Ethernet 10Base-T/100Base-TX - 25 pin D-Sub (DB-25) , 1.0 x Microphone - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 1.0 x Parallel - Output - RJ-11 , 1.0 x Network - Phone line - Mini-phone 3.5 mm , 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm , 1.0 x Modem - Input - RJ-45 , 1.0 x Display / video - VGA - 4 pin USB Type A , 3.0 x Hi-Speed USB
  • Miscellaneous
  • Features Power-on password , Hard drive password , Security lock slot (cable lock sold separately)
  • Compliant Standards ACPI , Plug and Play
  • Power
  • Power Device External
  • Voltage Required AC 120/230 V ( 50/60 Hz )
  • Power Provided 90.0 Watt
  • Battery
  • Technology Lithium ion
  • Installed Qty 1.0 / 2.0 (max)
  • Capacity 4300.0 mAh
  • Operating System / Software
  • OS Provided Microsoft Windows XP Home Edition
  • Software AOL , Drivers & Utilities , ArcSoft ShowBiz DVD , Norton Antivirus 2004 (3 months subscription) , Toshiba Custom Utilities , Microsoft Office OneNote 2003 , Microsoft Works , AT&T WorldNet Service , Toshiba Touch and Launch , InterVideo WinDVD 4 , Toshiba Notebook Maximizer , Toshiba Speech System , Toshiba ConfigFree , Adobe Acrobat Reader
Sep 13, 2011 | Toshiba Satellite A65-S126 Notebook
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
Is this system came with inbuilt speakers?
General
  • Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Width 7.6 in
  • Depth 7.6 in
  • Height 1.4 in
  • Desktop type Budget desktop system , Small-form-factor PC
Processor
  • Type Intel Atom N280 / 1.66 GHz
  • Installed Qty 1
  • Max Supported Qty 1
Cache Memory
  • Type L2 cache
  • Installed Size 512 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel GN40
  • Data bus speed 667 MHz
Environmental Parameters
  • Environmental standards EPA Energy Star
RAM
  • Installed Size 2 GB / 2 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667 MHz
  • Configuration Features 1 x 2 GB
Storage Controller
  • Type Serial ATA - Integrated - Serial ATA-300
  • Storage controller interface channel qty 1
Storage Controller (2nd)
  • Type None
Storage
  • Floppy Drive None
  • Hard Drive 1 x 160 GB - Standard - Serial ATA-300 - 5400 rpm
  • Hard Drive (2nd) None
  • Hard Drive (3rd) None
Optical Storage
  • Type None
  • Type None
Storage Removable
  • Type None
Monitor
  • Monitor Type None.
Graphics Controller
  • Type Integrated
  • Graphics Processor / Vendor Intel GMA 4500M Dynamic Video Memory Technology 5.0
  • Digital Video Standard High-Definition Multimedia Interface (HDMI)
Audio Output
  • Type Sound card
  • Sound output mode Stereo
  • Audio output compliant standards High Definition Audio
Telecom
  • Modem None
Audio Input
  • Type None
Networking
  • Data Link Protocol Ethernet , IEEE 802.11b , IEEE 802.11g , Fast Ethernet , Gigabit Ethernet , IEEE 802.11n (draft)
  • Compliant Standards IEEE 802.11b , IEEE 802.11g , IEEE 802.11n (draft)
  • Expansion Slots Total (Free) 1 ( 0 ) x Processor , 2 ( 1 ) x Memory , 1 ( 1 ) x PCI Express Mini Card
  • Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 6 x Hi-Speed USB - 4 pin USB Type A ( 4 in front ) , 1 x Network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x Display / video - HDMI - 19 pin HDMI Type A , 2 x Keyboard / mouse - Generic - 6 pin mini-DIN (PS/2 style) , 1 x Headphones - Mini-phone stereo 3.5 mm , 1 x Microphone - Mini-phone 3.5 mm
Printer
  • Type None
Miscellaneous
  • Features Security lock slot (cable lock sold separately)
  • Compliant Standards PC 2001
Power
  • Device Type Power adapter
  • Power Provided 65 Watt
  • OS Provided Microsoft Windows XP Professional
  • Software Acer Smartboot , Google Desktop , Google Toolbar , Acer PowerSaver , Acer Client Manager , Acer QuickMigration , Adobe Acrobat Reader , Veriton ControlCenter , CyberLink PowerDVD (OEM) , Acer eRecovery Management , McAfee Internet Security Suite (Trial) , Microsoft Office Professional 2007 (60 days trial)
Manufacturer Warranty
  • Service & Support 1 year warranty
  • Service & Support Details Limited warranty - 1 year
Card Reader
  • Card reader Card reader
  • Supported flash memory cards Memory Stick , MultiMediaCard , SD Memory Card , xD-Picture Card
Sustainability
May 27, 2010 | Acer Veriton N260GU2802CP (PSVA506017)...
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
How do i get the bluetooth to work on acer 3690
According to the specs on that model it doent come with bluetooth.
  • Networking / Wireless LAN Supported Yes
  • Wireless NIC Acer InviLink 802.11b/g
  • Data link protocol IEEE 802.11b , Ethernet , IEEE 802.11g , Fast Ethernet
  • Networking features Acer SignalUp
  • Networking standards IEEE 802.11g , Wi-Fi CERTIFIED , IEEE 802.11b
Jun 30, 2009 | Acer Aspire 3690-2196 Notebook
Fast ethernet LAN drivers not installed and gives error code 10
Go to setting,control panel,system,device manage then click the network adapter,then properties,in resources uncheck the box "use automatic settings" then click the change setting then "edit input/output range" and try using other value with no conflicting device then click ok.Then go back to device manager and check if the yellow exclamation point is still there
Apr 18, 2009 | Computers & Internet
LAN card connection problem
Which card are u trying to install , it should be a PCI card and will sit only on PCI slot.
Apr 02, 2009 | Intel D865GBF Motherboard
I want to know what is the content of ibm r50e thinkpad laptop
General
  • Platform Technology Intel Centrino
  • Built-in Devices Speaker , ThinkLight , Wireless LAN antenna
  • Width 12.4 in
  • Depth 10.2 in
  • Height 1.5 in
  • Weight 6 lbs
  • Color black
  • Localization English / United States
  • Notebook type
  • Budget
Processor
  • Processor Intel Pentium M 725 / 1.6 GHz
  • Data bus speed
  • 400Mhz Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GM
Cache Memory
  • Type L2 cache
  • Cache size 2 MB
RAM
  • Installed Size 256 MB / 2 GB (max)
  • Technology DDR SDRAM - 266 MHz
  • Memory specification compliance PC2700
  • RAM form factor SO DIMM 200-pin
  • Environmental & energy standards compliance
Storage Controller
Storage
  • Floppy Drive None
  • Hard Drive 30 GB - 4200 rpm
  • Storage Removable None
Optical Storage
  • Type CD-RW / DVD-ROM combo - Integrated
  • CD / DVD read speed 24x (CD) / 8x (DVD)
  • CD / DVD write speed 24x
  • CD / DVD rewrite speed 24x
Display
  • Display Type 14.1 in TFT active matrix
Video
  • Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Audio
  • Audio output type Sound card
  • Audio codec AD1981B
  • Audio output compliant standards AC '97 , DirectSound
  • Audio Input None
Input Device(s)
  • Input device type Keyboard , TrackPoint
Telecom
  • Modem Fax / modem - CDC
  • Max transfer rate 56 Kbps
  • Protocols & Specifications ITU V.90
  • Modem features V.92 upgradable
Networking
  • Data link protocol Ethernet , IEEE 802.11b , IEEE 802.11g , Fast Ethernet
  • Remote management protocol CIM , DMI 2.0
  • Expansion Bays None
  • Expansion Slots Total (Free) 1 ( 1 ) x CardBus - Type I/II/III , 2 Memory - SO DIMM 200-pin
  • Interfaces 2 x Hi-Speed USB - 4 pin USB Type A , 1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Modem - Phone line - RJ-11 , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 1 x Microphone - Input - Mini-phone 3.5 mm
Miscellaneous
  • Features Wake on LAN , Power-on password , Hard drive password , Administrator password , Security lock slot (cable lock sold separately)
  • Compliant Standards DDC-2B , ACPI 2.0 , ACPI 1.0b
Power
  • Power device form factor External
Battery
  • Technology 6-cell Lithium ion
  • Installed Qty 1
  • Mfr estimated battery life 4 hour(s)
  • Software Drivers & Utilities
Environmental Standards
  • EPA Energy Star Compliant Yes
Please rate this a fixya
Feb 11, 2009 | IBM ThinkPad R50e Notebook
Belkin 4-Port Router
this is because that router is a wired router not a wireless router
Oct 07, 2008 | Belkin (F5D5231V4-SN-PD) Router...
I have a toshiba Equium L300 & it cannot connect to a wireless router. I have been advised that it is missing a ethernet/wireless driver. Please advise
From what I see about the Equium, the name Equium is in use in UK only. In other European & countries USA the name is Satellite. From the specs of the model you mentioned you DO have a onboard NIC. You might have to uninstall the driver that you have due to corruption and the operating system will install a generic driver for you to use. Or you can go to Toshiba if you’re in Europe
http://www.toshiba-europe.com locate support and you can download the driver there.
If you have a driver your probably not setting (configuring the router and your computer) the network up properly.
Networking Networking: Network adapter
Wireless LAN Supported: Yes
Wireless NIC: Realtek RTL8187B
Data Link Protocol: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Compliant Standards: IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED
Jun 29, 2008 | Toshiba Computers & Internet
PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres Logo
323 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
