Question about HP Photosmart 2710 All-In-One InkJet Printer
HP 2710 Printer
I am having a problem with the printer as follow:
it is very slow in copying, it takes as much as 5 min per page
scan is same thing, it takes as much as 5 min per page scan time.
any recommedations ?
thanks,
Ray soni
    Genius:
  • 1,142 Answers
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Posted on May 30, 2008
Hp officejet 4355 all-in-one printer was very slow printing
Ok,if it is slow printing on faxing,than it depence from the sender or from network.But if prints sloly when you copy than try to make it faster on manu display,or try to open it and maybe is some peace of paper left inside and blocking it.
Jul 04, 2014 | HP Officejet 4355 All-In-One InkJet...
Can't make copies on hp 2710
Bar is going bad cause there is a problem with the track that its on or a problem with the board making it think it went the whole way. Its more expensive to have it fixed at a shop then to just buy a new one.
Apr 15, 2010 | HP Photosmart 2710 All-In-One InkJet...
HP Officejet 7210 Is Very Very Slow (10 mins / page printing)
And I have exactly the same problem too that has happened in the last few weeks.
I've tried reinstalling the software/drivers and resetting the printer to factory settings but no joy. An upgrade either windows or HP must have caused this!
Mar 29, 2010 | HP Officejet 7210 All-In-One InkJet...
Hp c6180 prints and copies very slow?
Here are the specs for your printer
http://h10010.www1.hp.com/wwpc/ph/en/sm/WF06b/18972-18972-238444-410635-410635-1153695-1153696.html
Your printer only can print up to 8.2 black pages per minute and only up to 6 color pages per minute. I think you just bought a really slow printer.
Jan 12, 2010 | HP Photosmart C6180 All-In-One InkJet...
The printer is telling me to replace the color print cartridge. I only want to print in black. i have a hp photosmart 2710
Your only problem here is that you own a HP inkjet printer.  This printer uses up both cartridges even if you print in black.  Donate this thing and get you a Brother laser printer that just prints in black.  This will cost less to operate per page and uses less energy.
Oct 25, 2009 | HP Photosmart 2710 All-In-One InkJet...
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP PSC 2410 very slow printing issue
It is a cartridge problem. Solution for my hp 3645 (I have the same story as bb18, but different printer) was to remove color cartridge!
The printer is fast now, of course it does not print in color :) (I`m waiting for a new color cartridge) Good luck,
Marcin
Dec 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart 2710 All-In-One InkJet Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
