I received this washing machine second hand and have no idea what the function buttons mean.please advise me if you can how to remedy this or fill me in yourself. Thank you Sincerely, Lucky to own this machine, but feeling lost
    President:
  • 1,937 Answers
Assuming that this is a Sears / Kenmore machine: see the following site for an operating manual:
http://www.managemyhome.com/
Click on the Manuals tab, enter the model number and you should be able to get a PDF version of the manuals.
Posted on Oct 10, 2010
Can you please advise what CL means on our washing machine (LG WD1049C)
CL usually stands for child lock , look for a button indicating LOCK or child safety maybe a childs face etc. once you locate this button push for 3-6 seconds to unlock.
Jan 12, 2011 | LG WM-12230FB Front Load Washer
Control locked How can I get this unlocked so the washer will wash again.
Your owners guide will advise you what buttons to push to get out of the conrol lock (child lock) function. Usually the console will also show you which button or buttons to press by holding them down for 3 seconds.
Aug 29, 2010 | Whirlpool Washing Machines
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Artison a1636 washing machine trips consumer box
well that means you have either a short in your machine or the motor is burned out.
Most likely the latter is the case.
try to spin the drum by hand. if it goes tough or make grinding sound the motor or bearing is your problem
May 13, 2008 | Washing Machines
What is the remedy for copier's red alarm button blinking & fax not working?
Do you mean the "Out of paper" alarm? Check that all paper trays have paper. The by-pass tray should be prperly set to receiv "Legal" size paper and have that size paper in that tray.
Mar 30, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Help me to wash!!
hi
    this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
cliff
Oct 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
