Question about Audiovox FPE3206 32 in. LCD Television
Sound but no picture audiovox FPE 3206 and it is still under warranty but no is authorized to repair in my area
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi ur tv backlight inverter is bad . order for new one &replace it
Posted on Nov 09, 2008
Power supply board pdp4294lv
Contact the authorized service center, to buy a genuine one.
Dec 20, 2013 | Audiovox fpe 3207 32 in. LCD Television
How can I hook up VHS or DVD to my Audiovox FPE 2608? Thank you for you help, LaCrecia
via a converter that will take your normal rca or component plugs into hdmi
Mar 24, 2011 | Audiovox FPE-2608 26 in. LCD TV
When I turn on tv the picture comes on for about a second then goes dark. Sound works perfectly. Same thing occurs with every other channel. Same thing happens in dvd mode., sound but no picture. I have...
Sounds like it could be a bad inverter for the screen lamp. If it is a bad inverter and the tv is still under warranty you should send it back for a replacement or repair. If the tv is not under warranty and you have some experience working on electronic devices you could probably find a replacement inverter online and replace the bad one.
May 20, 2010 | Audiovox VE927 9 in. Portable TV
I HAVE AN AUDIOVOX LCD WITH SOUND BUT NO PICTURE.HOW DO I FIX IT .WHEN I TRY TO GET INTO THE MENU I CANT SEE ANYTHING
I strongly believe that one of two things has happened:
1) the back light 'florescent tubes' lamp ballast power supply board has gone out.
2) One of the florescent tubes has failed taking out the lamp ballast.
Is the TV still under it's factory warranty?
If it is not I would call around some TV service providers in your area and get some estimates of repair. Fairly common item to go out.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
When turned on it Flickers
Mine started out like that, now flickers about an hour before it comes on. I don't turn it off anymore, it'll burn out one of these days and I'll get a better TV.
Jan 01, 2009 | Audiovox FPE3206 32 in. LCD Television
Audiovox 32in flat screen t.v.
then in that case you wil need to either replace it or if it has a garantee and it has not ran out get it replaced.
Jun 25, 2008 | Televison & Video
Audiovox FPE3206
I had the same problem on my Audiovox FPE 3206, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Apr 22, 2008 | Audiovox FPE3206 32 in. LCD Television
Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Feb 02, 2008 | Insignia IS-LCDTV32 32 in. Television
Audiovox FPE3206 32 in. LCD Television Logo
149 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
