Question about Fagor LFA-013 Stainless Steel Built-in Dishwasher
Hi. I have an innovation Fagor dishwasher. worked perfectly the first time. Next to the display screen is a place "op" and "fin". when i turned it on the second time the "op" light blinks continiously and no other button such is the operate button works. thanks
2 Suggested Answers
SOURCE: FAGOR DISHWASHER LFU073IT WITH F9
Problem with the distributor motor. It is a small white plastic part which receives water from the heater, and alternatively distributes water to upper or lower difussors. If the motor locks, or the internal sensor doesn't sense the position well, it will show F9. Motor can be repaired in most cases, and at last, it can be swaped
Posted on Sep 19, 2009
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
My door will not shut and there is no tension on
make sure the strike is adjusted correctly.. it may have gotten bent out of place.. the strike is the little metal tab that comes off of the top of the center of the tub and goes into the door when you close the door.
Aug 29, 2009 | Fagor LFA-65 IT Dishwasher
R31 screen lines
there could be a lose wire to you display card mine gets red lines some times and if i hit the right side a few times it goes away and it works fin after so idk if it will work 4 you but it does for me.
Jan 24, 2009 | IBM ThinkPad R31 2656 Notebook
FAGOR DISHWASHER LFU073IT WITH F9 COMING UP ON DISPLAY
Nov 28, 2008 | Fagor LFA-073 IT Dishwasher
Fagor dish washer VFU-05S
What do I do to overcome the fault 'F3' accompanied by beeping ?
Jul 15, 2008 | Fagor LFA-019 SS Stainless Steel...
Water not going in
This is a little late for the OP. But, I had the same problem over Thanksgiving of 2008. I searched online and saw that other people had the same problem, but there were no solutions posted. So, I paid $130 for a service tech to come fix the problem - maybe this will save you some time and money.
The solution was simple...pour boiling water (I boiled about a half gallon of water in a cooking pot) straight into the pump where the water sprays out of. You don't have to pull your dishwasher out and no tools are needed. Just open the door, pull out the lower roller tray, remove the bottom spray fin (just pull straight up), and pour the boiling water straight into the hole where the bottom spray fin was attached to. Next, put everything back in place, push the Power switch on, select a wash mode, and close the door. The dishwasher should start spraying water inside as usual.
The service tech told me that there are only two pumps in this dishwasher...one to pump the water in (the one that had the problem) and one to pump the water out. When you don't use the dishwasher frequently, the seal in the wash pump seizes up (sticks together). You can hear the motor humming, but the pump isn't able to send the water up into the spray fins. By pouring boiling water into the pump, it helps to break that stickiness and allows the pump to start sending water up into the spray fins. The solution is to run your dishwasher at least once a week. Even if you don't have much to wash, run a rinse cycle to let all the parts move and stay loose.
One other tip the tech told me is to pour a cup of white vinegar into the pump when you go away on vacation and the dishwasher won't be used for a week or more. This should keep the seals from sticking together. I haven't tried this yet.
Hope this helps.
Feb 20, 2008 | Bosch SHU9915UC Dishwasher
7 BEEPS!!!!!!!!!!!
Please contact the Fagor America Service Center toll free: 1-877-743-2467. A customer service representatives will discuss the problem with you. If on-site service is required, they will coordinate that for you.
Jun 15, 2007 | Fagor LFA-65 IT Dishwasher
Fagor LFA-013 Stainless Steel Built-in Dishwasher Logo
194 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
