Shore E5 low sound from left speaker - Audio Players & Recorders
    Scholar:
  • 63 Answers
It may be cause by either software problem or hardware problem..
Here is the solution,
Software solution,
  1. double click on the volume controller on the taskbar.
    (tips. it is situated at right bottom corner.)
    one new widow pop up.
    here you can adjust your volume.
  2. under volume control adjust a balance. make it to center.
    (tips. it deal with all your volume control setting. if you want to adjust your mic, or headphone sound setting you can use it.)
HARDWARE PROBLEM:
if above solution doesn't work then it can be hardware problem. to check plug out the speaker jack and slowly plugin . If sound travel from one speaker to another then assume that the problem is with your jack.. in this case you have to replace your speaker.
hope it helps you,
pls click on the thumb if you think it should. THANK YOU.
Posted on Oct 10, 2010
Why does it hum?
PDF]Eris™ E5 and E8 Owner's Manual - PreSonus
www.presonus.com/downloads/.../ErisE5andE8_OwnersManual_EN.pdf
to boost much, since this can add noise to the signal. The Low Cutoff ... you are using a subwoofer in conjunction with the Eris E5/E8 monitors, and set it to the ...
Aug 02, 2015 | AAD E8 Subwoofer
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
My volume went low.
These are speakers with their own power?
No? - Get some.
Yes - Win7 - If you speaker icon is missing go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or 5.1.
You should also check speaker connections for left speaker.
Oct 11, 2012 | HEWLETT-PACKARD ProBook 4520s
Voice of both left and righ speaker is not equal
Can say I've seen this on a H/K. First swap the speakers left to right and right to left if the sound is low on the same speaker its the speaker not the receiver (could have a driver out). Could also be a dirty output relay.
Is the sound good other than it being low?
Is it that way with all inputs?
Jul 17, 2010 | Harman Kardon AVR 25 MKII
How do I fit a Sony XR-C450RDS car stereo to my Ford Focus without the wiring fitting instructions? Could you tell me which wires should go where?
Radio Constant 12V+ Wire: Orange/Light Green
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black or Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Tan/Yellow
Left Rear Speaker Wire (-): Gray/Light Blue
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope this helps.
Aug 31, 2009 | Sony Car Audio & Video
Low audio level on left speaker
sounds like your left channel capacitor has slowly failed.
Jul 30, 2009 | Audio Players & Recorders
Very low sound out of left front speaker, other speakers work fine
Have you tried another speaker? If your left front speaker is in the door as in most cars, it gets banged around a lot. The driver's door gets the most use. This sometimes results in mechanical problems with the speaker, and can cause low sound or distortion. Take the speaker cover off (it may be necessary to remove the door panel in a factory installation), disconnect the speaker and hook another in its place. If the volume is back to normal you know it's the speaker. If not, check the radio and speaker wiring. If the radio itself is at fault because the amplifier is bad, it can be repaired at a service shop. The repair charges might be close to replacement cost these days, so you might consider a new radio if the estimate is high.
Apr 27, 2009 | Sony XR-M510 Cassette Player
Left rear speaker noise
The internal amp for the left rear speaker has a faulty transistor or IC chip this would need to be replaced.
Aug 21, 2007 | Creative Labs Gigaworks S750 Computer...
Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Mar 30, 2007 | iLO XM-MP3-CD Car Stereo
 Grubhead
Grubhead
