Question about Lexmark T630 Laser Printer
Lexmark T630 I keep getting the Error Code: 202 Paper Jam Rear Door When I open the rear door there, is no paper jam. So I go to the front & press the Green GO button over & over & it will eventually start again. It will only print a few pages & then it will do it again. Help!!!!!!!
    Genius:
  • 1,142 Answers
Repeated, Unexplained Paper Jams With Little or No Damage to the Paper ID:ENUS5286 Lexmark T630 - null.gif null.gif null.gif
IMPORTANT: The printer should rest on a surface that is flat, level, and uniform. This is for safety reasons as well as for paper feed reliability. In the bottom left corner on the front of the printer, as well as on the duplexer and each paper feed option apart from the 2000-sheet feeder, there is a shaft that rotates as the main drive motor in the printer operates. The purpose of this shaft (called the Power Take Off shaft) is to turn the pass-through rollers in the option below. The Power Take Off (PTO) shaft rotates during the printer's POR as well as any time the main drive motor turns, including while paper is feeding from any source and when the toner is agitated in the cartridge.
If the printer is on an uneven or non-level surface, the PTO shaft may not make full contact with the bevel gear on the lower options.
If the printer is on a surface that is not uniform (such as a carpet or foam padding), the PTO shaft on the lowest option may catch or bind, causing the paper feed operation to slow or stop completely.
In either case, repeated and unexplained paper jams (with little or no damage to the paper) may occur. The paper jam is due to the increased amount of time it takes the paper to feed through the path because the PTO shaft is bound or caught on the surface below, or is slipping on the bevel gear.
NOTE: This is not a printer defect or failure although it may result in a broken or stripped PTO shaft.
Posted on May 30, 2008
Error code 201 lexmark t630
201 is a paer jam message generated by the fuser (hot thing in the back of printer) remove rear door and the redrive unit. ( two screws on back of printer and press in two levers on upper portion of back to remove) either the switch on the left of the fuser is stuck or the switchneeds replacing (assuming it is a false paper jam)
Oct 15, 2013 | Lexmark T630 Laser Printer
202 Paper Jam, but there is no paper found at the rear door. Lexmark T630 Thank you very much!
Thank you very much! ????
I am not sure where you think you are posting, but to leave a comment like that is unlikely to get a favorable response.
This is an independant help site, this site has nothing to do with Lexmark, and so the thank you very much comment is unneeded, and unwelcome.
You may have paper stuck inside the machine, where you cant see it, If you had a jam, and pulled the parer out, some may have stuck inside, or you may have damaged something pulling it out.
You may have to take the printer apart to check
Sep 16, 2010 | Lexmark Office Equipment & Supplies
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
THERE IS PAPER JAMMED IN THE LEXMARK T630 AND WE CAN'T GET IT OUT
first you take out toner cartridge and see if paper is jam in fussing unit otherwise open the back side door and take out fussing unit and clean the paper jam
Feb 05, 2010 | Lexmark T630 Laser Printer
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
Lexmark T630 Error message "Paper Jam Remove rear cover." No paper jam...
Open the rear, there is one of the paper sensor actuators stuck. They are spring loaded and should spring back when pushed out by the paper.
Oct 14, 2009 | Lexmark T630 Laser Printer
202 Paper Jam
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Lexmark T630 Laser Printer Logo
1,364 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
