I have Old Microtek Monitor.Its showing yellow colour now some times when i shake the cable its showing normal display. Pls help regaring this.. Regards Paddy
    Scholar:
  • 63 Answers
You don't need to worry about it.
it is because of you jack.
If it disturb you, then you can tighten your jack,
again it happens then you need to replace your jack..
; ) for any helps don't hesitate to ask.
if it help you pls rate it.
Posted on Oct 10, 2010
~Hello! My monitor dispays picture, but the picture isnt like it should be. Instead of normal colours it displays gray stripes, red is shown as yellow, windows 7 startup icon is in black box ect. When...
Hey, have you bene able to try another monitor and see if its the same thing?
Check andmake sure that all of your cables are tight and secure. If they are then you probably have a bad video card. they are fairly easy to replace:
Jul 15, 2011 | BenQ FP737S-D 17" LCD Monitor
The microtek crt moniter is not displaying green colour.
The electron cannon from inside the tube for the green has failed, the tube and the entire monitor with it is dead - time for a new one.
May 21, 2011 | Microtek Computers & Internet
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
My LG monitor E700S displays yellowing colour instaed of white. Pls suggest
please try to change the rgb cable /and before try to connect the cable properly to the graphics card and all the pins i good.also go to the menu of the monitor and set the colour temprature to cool .its should be good
thanks
Dec 10, 2010 | LG Studioworks 700S 17" CRT Monitor
MOnitor Display
1. cheak the display cable.
2. Solder the dry points on the neck board.
Dec 19, 2008 | Computers & Internet
I have a microtek 17' monitor model is 41f
This can be caused by low Screen Refresh rate. Eg 60Mhz. To increase this go to Display propertes > Setting > Advance > Monitor > Screen Refresh rate
Your graphic driver must be installed correctly to be able to make this change.
Please tell me If this dont fix
Best regard
Dec 05, 2008 | Microtek Computers & Internet
Yellow dispkay
the display turns to yellow when the blue colour is missed form cable. check the vga cable or may be it's from inside monitor. from the vga card. check the cable first then call or mail....
Feb 22, 2008 | Microtek C893 18.1" Flat Panel LCD Monitor
Monitor problem- colour changes to white appearance to yellow appearance
COLOUR MONITER BASE COLOUR IC SOLDING AND BASE SOLDING OR CHEAK DATA CABLE
Mar 18, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
