Question about Cozy (W352E) Heater
My wall unit cozy heater goes on when I turn on the thermostalt but it goes out one minute later. What is the cause?
  • sam brown Oct 12, 2010
    need the model number of unit
  • 59 Answers
By pass the wall stat, pull the 2 wires off stat and twist together and if unit runs ok it is the stat if it does the same thing by pass the stat wire by disconnecting the stat wires from the valve a put a jumper wire between the (th) terminals.
Posted on Oct 12, 2010
I have a cozy model cdv255 direct vent wall furnace and the pilot light keeps going out. What causes this
dirty fuel line.have see where spider web is enough blockage to cause this. but aslo have found that the thermocouple needed replaced.
Jan 08, 2015 | Cozy Heating & Cooling
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
New cozy wall heater makes alot of noise from heatexchanger poping and banging noises
if this is a w series unit measure from the top of grill to the floor, should have 68 3/8 on an inch if not the header plate which is installed in the wall was put in wrong have the installer correct this and the noise will go away. Cozy tech line is 502-589-5380 have the installer call so they can go over the install of the unit.
Dec 06, 2010 | Cozy (W352E) Heater
I Have A Cozy Space Heater And It Will Work For Awhile Then Goes Out, Relight The Pilot It Stays On Turn The Heater On And It Will Work Awhile Then It Shuts Off Again
if you have the vent pipe in a chimmney or vented outside wall can cause this problem, need to either put a liner in chimmney or vent insde the room with the heater up thru the ceiling.
Oct 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
My natural gas wall heater turns on for a minute and you can see the flames lapping on the outside of the metal box that goes up the wall. Then it goes out.
HI turn it off you have a blocked flue . you have flame roll out possable fumes coming in to the room do not use this get a gas fitter in to fix this asap
Dec 20, 2009 | Cozy (W352E) Heater
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
My Cozy heater does not respond on the thermostat control
Make sure you have a stat that is for a millivolt system, if the stat you have has 24v on it wrong one, need to purchase at a heating wholesaler home depot lowes do not carry them.The stat should have mv for millivolts on the box or stat.
Nov 23, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
97 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
