Need a manual for panasonic inverter cs/cu e9hkr - to download please
SOURCE: CS-E9HKR PANASONIC A/C UNIT DOES NOT BLOW COOL AIR
change the filter whash the coil
Posted on Nov 10, 2009
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
  • 34 Answers
SOURCE: I have a Panasonic CS/CU-W18DKR - on cooling it
When the unit heats inside, the outdoor unit cools, and if the outdoor cooling coil gets too cold the system turns off indoor fan, and changes gas flow direction to de-ice the outdoor coil. Ensure both coils, and the filters are clean and if there is still a problem check system gas pressure for leaks.
Posted on Apr 24, 2010
jyackle5
  • 8197 Answers
SOURCE: we live in a remote
You can get the service manual on the link below. It tells you what the code means on the manual and how to fix. Open the link in a new window to download it.
http://www.coolzoneairconditioning.com/upload/CS-CUE9-12GKR.pdf
Good Luck
Posted on Aug 29, 2010
hvac1960
  • 2133 Answers
SOURCE: FAULT CODE H19? WHST IS
H-19 Error code means indoor fan mechanism locked. replace fan.
Posted on Dec 12, 2010
Owners manual Panasonic inverter 2.2 cu ft microwave oven
Fairly sure you can download one from the Panasonic website. I did for my inverter combination oven.
Dec 10, 2017 | Panasonic Microwave Ovens
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Panasonic Inverter Manual
go please to www.fitness.manualsonline.com or www.retrevo.com and download free.
God bless you
Oct 31, 2013 | Microwave Ovens
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-SD376S
Desperately need
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-K593MF. please help
Jul 20, 2009 | Microwave Ovens
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
