Question about Sanyo SBM-20 Bread Maker
The mixing blade is stuck in the tin . How do we get it out?
    Genius:
  • Sanyo Master
  • 1,280 Answers
Try soaking it over night or even for a couple of days. Put just enough water in it to cover the paddle completely plus about an inch with a little detergent. Whatever you do don't try to pry it loose with anything metal because you will damage the nonstick coating on the paddle and/or the breadpan!!!..............If it still won't come out log on to you tube and type in "How do you remove a stuck bread machine paddle" ......you will see my video of how to remove a seriously stuck bread paddle with no damage to your pan or paddle.
Posted on Oct 10, 2010
  • pmouncey Oct 10, 2010
    Hi Daryl,
    Thanks. I had tried soaking it so I tried your shoe lace trick. Snapped the lace! I'll try soaking for longer and then try the lace trick again. It seems so simple and logical.
    I believe it has been stuck for some time maybe even more than a 1 year.
    Thanks. S.
  • Daryl Nash
    Daryl Nash Oct 11, 2010
    just soak again for several days then use short little pops over and over again. It should pop off. The one in the video was the worst one I ever had. You might have to get a good strong shoelace from the store. Maybe they make some with nylon that would be really strong. keep me posted
Need recipes for brownies.
Ingredients
  • 200g dark chocolate.
  • 100g unsalted butter, very soft.
  • 250g caster sugar.
  • 4 large free range eggs, beaten to mix.
  • 1tsp vanilla essence.
  • 60g plain flour.
  • 60g cocoa powder.
  • 15cm square brownie tin or baking tin greased and base-lined.
Chocolate brownies recipe - goodtoknow
www.goodtoknow.co.uk/recipes/148909/Chocolate-brownies How to make perfect brownies
Dec 03, 2016 | Kitchen Appliances - Others
How do i replace the rear wiper blade on a 2007 Kia Sportage?
remove the small tin lock/wedge at the end of the wiper blade and pull it out of the frame
Thread the new blade back in and refit the lock
Jan 20, 2015 | 2007 Kia Sportage 2.0
Need instructions for DQ Blizzard Maker
1st add crushed ice and equal water outside the tin in the blizzard
2nd add 3/4 of salt to the the salt water
3rd put the cap on and in a separate cup mix ice cream mix and 3/4 of half and half and mix until completely dissolved
4th put the mix in the tin cup and add the cap
5th stir with flat spinner not the swirly one spin for 10 min when done push ice cream with swirly stirrer
Nov 01, 2013 | Spin Master 1001130 DQ BLIZZARD MAKER
Im looking for a banana bread receipe
Banana Bread
Ingredients
285grams plain flour
1 tsp bicarbonate soda
half teaspoon salt
110grams butter, plus extra for greasing
225grams caster sugar
2 free-range eggs
4 ripe bananas mashed
85ml buttermilk (or normal milk mixed with one and half teaspoon Lemon Juice or vinegar)
1 table spoon Vanilla Extract
Preparation method
Preheat the oven to 180Celcius 350Farenheit Gas 4.
Sift the flour, bicarbonate of soda and salt into a large mixing bowl.
In a separate bowl, cream the butter and sugar together until light and fluffy.
Add the eggs, mashed bananas, buttermilk and vanilla extract to the butter and sugar mixture and mix well.
Fold in the flour mixture.
Grease a 20cm x 12.5cm/8in x 5in loaf tin and pour the cake mixture into the tin.
Transfer to the oven and bake for about an hour, or until well-risen and golden-brown.
Remove from the oven and cool in the tin for a few minutes, then turn out onto a wire rack to cool completely before serving.
Aug 12, 2013 | Computers & Internet
My bread stuck to the pan and it rose to much.
Remove the container from the breadmaker and use non-stick fish-slice or palette knife to free the sides from the tin. Then tip upside down and shake to dislodge it.
If this fails, remove the bread as best you can and leave the tin to soak in water overnight.
It is best to clean the bake tin by hand as dishwashers remove the non-stick.
Try using packet mixes with a different packet dried yeast. or use less yeast next time.
Feb 08, 2010 | Kitchen Appliances - Others
Mixing paddle won't turn.
The mixing paddle is supposed to turn by means of a lubricated bearing. This bearing is broken or stuck so the blade will not turn.
Try soaking it overnight in soapy water. If that does not work it's time for a replacement pan if you can find one.
Hank
Oct 04, 2009 | Sunbeam 5833 ExpressBake Bread Maker
The mixer blade won't mix. The motor runs but blade won't go.
Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
Hank
Sep 14, 2009 | Oster Kitchen Appliances - Others
White stripe in print-outs
This is a common problem with this printer. Each toner color has it's own roller. The tin blade on the inside edge of the roler gets plasticy buildup and needs to be cleaned.
Pull out the entire toner roller assembly for the color that is problmatic. Unscrew the tin blade from the roller assembly. Clean the inside edge of this blade (the part that scrapes on the roller) completely. NOTE: After cleaning mine with toilet paper & water I ran my fingernail along the edge to find that the waxy buildup was still there. I gently took my fingernail and scraped at it until it felt smooth -- no burrs.
NOTE: The edge of this blade is very sharp! Be careful. Don't run your finger along the edge.
Reinsall the tin plate maing sure that the foam sweeps (on the right and left of the blade) are not stuck under the tin blade. (If you do, it will dump large amounts of toner on your pages. Very messy).
Give her a whirl.
Apr 05, 2009 | Samsung CLP 300 Laser Printer
I can't find the paint code for my isuzu trooper 1993. 777/153. but can't get the colour . i took this code to halfords 777/153 but they cant mix the paint were can i get it from?
go to a body shop and ask for a tin and they will mix it ,but be warned its expensive as only new paint which is bio degradable can be used.1993 this is an old jam jar,i used to repaint with a hamiltons paint brush and some fleet teckaloid in my time,and if you couldnt afford the coach paint then a tin of wollies special and a cheepo brush
Apr 02, 2009 | 1993 Isuzu Trooper
Sanyo SBM-20 Bread Maker Logo
148 people viewed this question
Top Sanyo Kitchen Appliances - Others Experts
David Payne
David Payne
Gerry Harvey
Gerry Harvey
Irene Tulloch
Are you a Sanyo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
