Question about Lanier 1205 Copier
Hi.i have a problem with the lanier ld024c code error 571 ? what is it \r\nand what to do ?
3 Suggested Answers
  • 161 Answers
SOURCE: error sc 571
there is too much oil in the fuser tank(there should be little oil)
SC 571
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
you need to enter the service mode to clear the error(service tech only)
Posted on May 08, 2009
  • 990 Answers
SOURCE: SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Posted on Feb 02, 2010
Service code sc301 on a lainer ld0105
http://copierquestions.messageboardchat.com/post/ricoh-savin-and-lanier-error-codes-3442638
Looks like it's a Charge Corona Output Error 2 - Charge Current Leak
Lanier is now owned by Ricoh (Savin and Lanier) ... you should contact them for repairs if you are not qualified to repair it yourself. Remember, there are very high voltages in there and you can do serious harm to your printer ... or worse, YOU.
Mar 01, 2014 | Office Equipment & Supplies
Nand flash rom error
I'm afraid it is the switch that is giving the Nand memory error, but can't verify this, because I don't know what model you are using. I can't find an error like this in the Epson high performance printer.
Do you know what switch you are using? Cisco has thousands.
Oct 29, 2013 | Office Equipment & Supplies
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
SC 571 error
Feb 02, 2010 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Error sc 571
SC 571
Oct 28, 2008 | Office Equipment & Supplies
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Feb 11, 2008 | Office Equipment & Supplies
57 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
