Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I closed the safe after use , the proceed light came on , i put the code in again & it doesn't function. i dont have a key.
  • Graham Oct 25, 2011
    I changed batteries in CE t25e digital safe and it shows no sign of life with the door shut, how can I open it
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Can't get it open after keying in code. error
http://www.sentrysafe.com
the instructions are located link above.
mj
Jul 08, 2009 | Sentry Fireproof Safe
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Aug 20, 2008 | Computers & Internet
Green proceed light goes on but door does not depress lock
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Feb 03, 2008 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
41 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
