Question about LaCie Electron 19" CRT Monitor
Video output in lacie electron 19blue - LaCie Electron 19" CRT Monitor
Lacie electron blue desktop rolls over top of monitor
I agree--you need to first try another monitor. Sounds like a monitor problem to me.
Jun 28, 2012 | Computers & Internet
LaCie Hard Disk USB 2.0 1 TB i lost the power
this unit is compatible with a few of LaCie power supplies, but it is generally sold with the one providing hte following:
DC Output: 12V (2A) 24W
Regards,
Jan 19, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Turns on, no video.
How do you know it's recognizing the input? Black screen on a CRT monitor usually mean the horizontal output circuitry has failed impeding the flyback from producing high voltage. If this monitor is really important to you most reputable repair people still repair them. However, it may be overall cheaper in the long run to dump it and get an LCD monitor.
Feb 25, 2010 | LaCie Electron 19" CRT Monitor
Lacie Electron 19 Blue IV went dead after a power surge,
yes its in power unit.
if you think the fuse is gone and you have ability you can change.
Jun 02, 2009 | LaCie Electron IV 19" CRT Monitor
Fried HD?
Yep, it's probably fried, a little too much juice went in.
While the drive itself might be ok, the external casing is another story.
Try opening the case and removing the HD and plugging that in on your PC directly as a slave drive.
Sep 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Cables
Justa VGA monitor cable and a USB for th hub
Aug 25, 2008 | LaCie Electron III 22" CRT Monitor
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Intermittent problem
Could be dry solder near vertical Ic and horizontal Output Transistor.Resolder components mounted on heatsinks.
Samir.
Mar 09, 2008 | LaCie Electron 19" CRT Monitor
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
LaCie Electron 19" CRT Monitor Logo
26 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
