Question about Breadman TR888 Corner Bakery Bread Maker
My bread pan has all the coating worn off on the inside. The bread sticks badly to the pan and is hard to get out. I need a new bread pan!! What can I do ?
    Genius:
  • Breadman Master
  • 1,280 Answers
Here is a link to the breadman website maybe you can order a pan from them:
http://www.breadman.com/t-customer-care.aspx
Posted on Oct 11, 2010
They are peeling inside. Only had 3 years. What do I do?
bakers use black steel trays in which to bake bread
they are only covered in butter to stop sticking so if you follow the same procedure it will be alright
the covering that is coming off is probably the non-stick teflon coating which medical evidence proves not to be good for us as it breaks down with heat and age and is basic carcinogenic in nature
Look at all your old non stick pans and ask yourself , where did all the covering go?
Dec 15, 2015 | Kitchen Appliances - Others
How can I get a new pan?
Are you waiting for a few minutes for the loaf to cool down and shrink a little? Perhaps you have too much water in your recipe and not enough oil.The bread should never stick, unless you have been using a metal scouring pad on the inside of pan.Has it just started to stick?
Contact manufacturer to get new pan. But also make sure you are putting the ingredients in, in the exact order in which they are given.
Best wishes.
Jul 21, 2014 | Black & Decker B2300 Bread Machine
Bread sticks to the bread pan, Can't get it out of the pan when finished. Can I buy a new pan?
Unless the non-stick surface is worn off your bread should not be sticking. When it's done do you turn the pan upside and shake vigoroursly up and down and side to side over the countertop? It should start to slide out. I have owned over a dozen different machines and I have never had the bread stick in any of them. It is best to try to remove the bread right after it has baked and use hot pads or hot pad gloves are best. If it is really stubborn try turning the little "T" on the bottom back and forth. Eventually your bread should come out if you stay with it. Shake!, shake! shake!
Oct 29, 2010 | Toastmaster 1142 Bread Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
Bread sticks to the pan
check the pan and see if it needs to be replaced. if it is scratched and worn the teflon coating isn't working properly
Jun 21, 2008 | Breadman TR444 Bread Maker
Bread sticks to pan
May be that the coating on the pan is just wearing off. Had the same problem several years ago and it was just that the poor old machine was over used and the simplest solution was to buy a new pan. That machine went though 2 of them before it died its self.
- Neil
May 25, 2008 | Breadman TR444 Bread Maker
Seasoning the bread pan in my Bread machine
Teflon is a coating. Seasoning is not the term for your problem. It needs a new pan. Or get it recoated. Good luck.
Mar 25, 2008 | Kitchen Appliances - Others
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Breadman TR888 Corner Bakery Bread Maker Logo
150 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
